-   -   Missing Pages from 16V Engine Manual (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/802172-missing-pages-16v-engine-manual.html)
beamishnz 03-20-2014 06:14 PM
I'm planning to change the camshaft chain on my S2. I've checked a few pdf versions of the Factory Manual and they are all missing pages 15 - 101 and 15 - 102 which are the pages that relate to this procedure ... they jump straight to 15 - 103 which is about resetting the cam timing but nothing about removing and refitting the chain :(
Anyone with a hard copy kind enough to scan and send me the missing pages ?
PM me and I'll flick through my email details.
Many thanks
Paul
ernie9944 03-20-2014 07:30 PM
Many thanks
Paul
Just Google DIY Chain Tensioner Pad Replacement 944S2 -Rennlist D ...:D
Techno Duck 03-20-2014 08:22 PM
I am looking at a hardcopy right now, you really dont need the pages.
15-101 just lists the special tools for setting the cam timing.
15-102 describes setting the engine at TDC.
If you really want i can scan the pages and email you a PDF, but like i said not really critical info.
John_AZ 03-20-2014 09:25 PM
Old Post:
http://forums.rennlist.com/rennforums/10120190-post3.html
from...
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/734456-factory-wsm-vol-1a-needing-missing-page.html
J-az
beamishnz 03-20-2014 09:26 PM
I've found lots on the pad replacement but looks like you can do that without upsetting the cam timing ... I'm needing to do the chain so cam timing will need to be redone.
I've had a look at the Clarkes garage write up by Derek Holliday but I normally like to read the workshop manual too. I've not done it before so am a little nervous! :)
CHICKS 03-21-2014 07:33 PM
I posted the pages not to long ago, do a search of my user name.
beamishnz 03-21-2014 08:50 PM
Thanks guys. Got them. John AZ... sorry I posted just at the same time as your last post so didn't notice problem was solved. Now I have no excuses :)
