thermo cold start switch
does anyone have picture of 1979 thermo switch or location. all I have is wiring diagram
Old 03-28-2014, 05:36 PM
In the Fires of Hell.....
kdjones2000's Avatar
Down low on the back of the head.
Near your oil pressure sensor and coolant temp sensor.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-28-2014, 05:42 PM
there is a pipe with 3 sensors 2 vacuum and one temp with elec connections is that it
Old 03-28-2014, 05:55 PM
No, it is directly screwed into the head. Way in the back, very hard to see.
You will get a better view of it from underneath the car, looking up at the bell housing.
Old 03-28-2014, 06:05 PM
found it nothing connected 2 it this car is wiring night mare
Old 03-28-2014, 06:26 PM
