here i go again help
the starter is turning fly wheel and front crank shaft pully but nut engine this car has been sitting . so jumped seliniod and looked threw clutch hole see it moving flywheel . turned fly wheel with starter off turns front crank pully so why isn't motor turning old owner said smoke came up where radio is maybe has something 2 do with clutch hope u can help
Old 03-30-2014, 02:51 PM
alan6272's Avatar
To me you say the crank is turning, maybe the timing belt is broke and the valves are bent so motor will sound as though its not turning but in fact the pistons are but the camshaft is not? This will sound like a fast spinning.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 03-30-2014, 03:17 PM
already tock of f cam box and checked for bent valves leak down test but been messing with starter . it did something now because its pumping oil though cam shaft box were it wasn't before and piston are moving but starter still sounds bad im going to put back together and see what happens but would clutch assembley have any thing to do with it
Old 03-30-2014, 04:10 PM
kens_74_911s's Avatar
Goat
Billy, you need to let us know what you are working on before you ask how to fix it or other questions about your problem(s).
Different motors and timing 924 VS 944 etc.
I see you doing similar on the 924.org forum, so get that in up front in your initial "ask question" and save anyone that may want to help, some time/effort.
Clutch only disables the flywheel/engine from the torque tube and trans ( if in gear). So if flywheel is turning you are in netural~
K
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 03-30-2014, 06:25 PM
easydave
dave1192's Avatar
If the flywheel and the crank pulley are turning, the motor is turning. What do you mean by "the motor isn't turning"?
Easy Dave
Old 03-30-2014, 10:12 PM
1984 944
Old 03-31-2014, 02:18 PM
rotor
Mr Bill
Pull the Ft cap on your your "cambox" where plug wires exit and internal main spark rotor lives. Look at that rotor. It sends spark to 4 cylinders when it spins and gives an indication if cam is still driven my the timing belt.
Let us know if thats turning when "motor / flywheel" part spins with your lower motor parts / starter driven .
Old 03-31-2014, 07:17 PM
Mr Bill
+1
yea maybe or not so fast...
Ha Alan I just noticed it was your comment !!
Old 03-31-2014, 07:21 PM
its the starter it turning motor over but sounds like some buddys ass. im putting motor together have timing belt back on so im going to go from there . have tried three different starters somethings messed up there ill figure it out
Old 03-31-2014, 08:02 PM
