@ Qustion with regards to CV replacement
1-I recall that somebody was making locking bolts/studs for the CV joints/shafts, can't somebody point me to the supplier
2- I can't find the 8mm 12 point internal tool locally, preferred tool supplier? Thanks so much for the help |
The looking bolts are unnecessary if the bolts are installed properly. However Ideola's Garage sells the Stage 8 locking fasteners.
I think Pelican sells the triple square bit, if not I just search online for the place that has the most reasonable price and shipping.
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
You should be able to get the triple square at Auto zone or other stores.
I have bought a few sets at the first store I've gone to (when they were needed and forgotten, needed unexpectedly). |
There is good one made by empi, I think it was $8 shipped.
1990 944S2
I got my set of four from Autozone for around $8 on V2's recommendation.
84 944 gold sold 90 944S2 black current DD 89 735il white fixing 89 GL1500 white restoring, 01 955i S3 black current DD 01 955i Sprint brg customizing, 89 955i Daytona gold restoring |
Andrew Gawers' Dad
Yeah Ideola sells them. He might still be doing his sale on them too....
Proprietoristicly Refined
Ideola's Garage: Suspension Upgrades or Lindsey Racing LOCKING CV BOLT KIT 8x50mm 24pc. 924 ALL / 944 ALL / 968 / 911 '75 thru '84 (#4) at LINDSEY RACING - Your Porsche Performance Parts Center or Pelican!! $1 each. Pelican Parts - Product Information: N-911-082-01-M36 J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
And while I'm there , what's a decent synthetic gear oil to use on open 944 transaxle ?
Synthetic=Redline MT90
Andrew Gawers' Dad
Redline MT-90
The redline stuff is worth the money. It fixed my cold-trans hard shift into 2nd. Quieted things down, too. Shifting is way more slick.
If I was worried about this I'd use safety wire star washers and hex heads. Or tab washers. Or make some D shaped washers and bend the other side up to lock the hex head.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
I put Redline into my 924 w/the dogleg box and it helped a lot.
However Redline didn't really help the 951's 016. When cold I can't shift into 1st, once it warms up it is fine. So I'm going to drain it and try some Swepco 201. If that doesn't work, then I know for certain the syncro's are shot on at least 1st gear and will continue with refreshing the S2 trans I picked up. Just food for thought.
