@ Qustion with regards to CV replacement
1-I recall that somebody was making locking bolts/studs for the CV joints/shafts, can't somebody point me to the supplier
2- I can't find the 8mm 12 point internal tool locally, preferred tool supplier?
Thanks so much for the help
Old 04-01-2014, 06:15 PM
fiat22turbo's Avatar
The looking bolts are unnecessary if the bolts are installed properly. However Ideola's Garage sells the Stage 8 locking fasteners.
I think Pelican sells the triple square bit, if not I just search online for the place that has the most reasonable price and shipping.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 04-01-2014, 06:38 PM
You should be able to get the triple square at Auto zone or other stores.
I have bought a few sets at the first store I've gone to (when they were needed and forgotten, needed unexpectedly).
Old 04-01-2014, 06:40 PM
944tothefloor's Avatar
There is good one made by empi, I think it was $8 shipped.
Old 04-01-2014, 07:25 PM
1990 944S2
Send a message via Skype™ to ChrisRL
I got my set of four from Autozone for around $8 on V2's recommendation.
84 944 gold sold
90 944S2 black current DD
89 735il white fixing
89 GL1500 white restoring, 01 955i S3 black current DD
01 955i Sprint brg customizing, 89 955i Daytona gold restoring
Old 04-01-2014, 08:56 PM
Andrew Gawers' Dad
CHICKS's Avatar
Yeah Ideola sells them. He might still be doing his sale on them too....
Old 04-02-2014, 03:34 AM
Proprietoristicly Refined
John_AZ's Avatar
Product info:
Ideola's Garage: Suspension Upgrades
or Lindsey Racing
LOCKING CV BOLT KIT 8x50mm 24pc. 924 ALL / 944 ALL / 968 / 911 '75 thru '84 (#4) at LINDSEY RACING - Your Porsche Performance Parts Center
or Pelican!! $1 each.
Pelican Parts - Product Information: N-911-082-01-M36
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-02-2014, 05:25 AM
And while I'm there , what's a decent synthetic gear oil to use on open 944 transaxle ?
Old 04-03-2014, 05:05 PM
John_AZ's Avatar
Synthetic=Redline MT90
Old 04-03-2014, 05:15 PM
Andrew Gawers' Dad
CHICKS's Avatar
Redline MT-90
Old 04-03-2014, 05:19 PM
The redline stuff is worth the money. It fixed my cold-trans hard shift into 2nd. Quieted things down, too. Shifting is way more slick.
Old 04-03-2014, 07:26 PM
If I was worried about this I'd use safety wire star washers and hex heads. Or tab washers. Or make some D shaped washers and bend the other side up to lock the hex head.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 04-04-2014, 06:19 AM
I put Redline into my 924 w/the dogleg box and it helped a lot.
However Redline didn't really help the 951's 016. When cold I can't shift into 1st, once it warms up it is fine. So I'm going to drain it and try some Swepco 201. If that doesn't work, then I know for certain the syncro's are shot on at least 1st gear and will continue with refreshing the S2 trans I picked up. Just food for thought.
Stefan
Portland, OR
Old 04-04-2014, 06:32 AM
