1981 924
I got 924 I was told that the cold start valve was out so ireplaced it and it still wont start it seems like its not getting any gas I tried using starting fluid it tried to start help!!
Maybe it's not getting any gas? Check fuel pressure, fuel pump, fuel pump relay, fuse, related items.
What year car?
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
Toofah King Bad
Start by checking for vacuum leaks. CIS hates vacuum leaks.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
81
When was the last time it ran?
87 924S 82 924-Gone. 80 924 parts car-Gone. |
2 years
I have traced it to a vacuum leak I can get it to start if I manually use the vacuum pump from inside the air filter housing
Toofah King Bad
Smoke test it. Correct vacuum leaks, drive!
Can you give an idea or method to do that
Good luck, George Beuselinck |
Thank you
