ViolentBlue's Avatar
Send a message via ICQ to ViolentBlue
1980 924 turbo speedo cable
adapting the trans from a 924 turbo to a different application. does the g31 use a speedo cable?
all the ports are nicely capped for transit, any idea which one is for the speedo?
a few pics of my project
Old 04-06-2014, 06:07 PM
plays with toy cars
sausagehacker's Avatar
I thought the cable ran from the grease cap on DS front wheel to speedo pod in the dash?
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 04-06-2014, 06:49 PM
fiat22turbo's Avatar
On the 924's the speedo is driven like a Beetle or early 911, off the front wheel. Only the later 944 and other cars were driven off the trans.
Old 04-07-2014, 05:43 AM
good to know.
I had thought the 924 used Golf mk1 derived front suspension, so assumed the speedo would be cable drive like the golf.
if the speedo input of the car its going into is a 1:1 with the final drive, I can probably make something that will work
Old 04-07-2014, 07:37 AM
Originally Posted by ViolentBlue View Post
good to know.
It does use Golf/Rabbit Mk1 front suspension, reversed with different upper strut mounts and uprights which are closer to those on a Super Beetle. Rack is a modified RHD Rabbit manual rack flipped around, etc.
The cable is driven by the wheel bearing cap via a square hole in the cap like the beetle, 911 and 914. Lots of solutions abound to drive the speedo electronically or to swap it out for a later VDO unit, etc.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 04-07-2014, 09:17 AM
trying to make the car look as if VAG had built it themselfs from their parts bin. need to figure out how to keep the original speedo in the car.
Old 04-07-2014, 08:17 PM
