does anyone have details of how to take out the clock on 1983 944 I am baffled at this point
also have trouble with hood cable, it got bound up on front headlight and had to remove from latch and when redid wire thru latch, and now cable won't move latch at all __________________ This post was auto-generated based upon a question asked on our tech article page here: |
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick |
remove the heater sliders and knob, there are two screws under the heater control plate. remove the screws and the plate will come off.
there are two screws in the corners of the clock bezel, remove those. then, pull forward on the bezel and it will pop loose from its clips. clock is held on by two thumb screws on the back of the bezel. shouldn't take more than 1-2 minutes. |
Second post actually...
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/805002-clock-replacement.html |
| All times are GMT -8. The time now is 09:07 AM. |
