fuel pump relay
jumped relay with y jumper fuel pump works put in new relay the question is does fuel pump only run when starting.also put new ign switch in how should I check for spark and fue lthanks bob
Old 04-16-2014, 03:11 PM
BReif61's Avatar
You can buy a spark tester at your local FLAPS, or do the more shadetree version and take the spark plug out, plug it back into the boot, and ground it against the head and crank the engine. If you do this, MAKE SURE TO DISABLE THE FUEL PUMP. Or have a fire extinguisher handy.
Or just buy the tester. They're cheap.
-Brad
Current: Pair of 1986 944's
Past: 996 C4S
Old 04-17-2014, 10:28 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Billygoat,
That's good it works. Yes it will run when engine is cranking and running as well. recommend Clark's Garage test procedures which are straight forward.
Clark's Garage Shop Manual Index
Keep us posted, later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968 & 911 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 04-17-2014, 10:31 AM
