OK, here's a stumper...
86 n/a, has spark, proper timing, getting fuel, no vacuum lines missing or broken, swapped out the computer from a running car, new reference sensors and has tach bounce, replaced and even jumped the dme relay, tried starting fluid, and it still won't start. Any suggestions? Thanks for advice...
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
one of gods prototypes
Check that the rotor is in time with the cam gear, if the tiny Allen screw falls out it can spin and not be in time with the cam. .... But can still show spark. .....
Straight shooter
Compression test?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Compression is great, rotor...I'll check that tomorrow.
Not the rotor...
Straight shooter
Firing order.
Firing order is correct...Thanks for the idea
Back from Beyond
Getting fuel, but are the injectors firing?
Straight shooter
When you say getting fuel, where are you testing from? Something was missed in the trouble shooting.
Fuel is coming to the rail and the injectors are from a used, but running car. It should still run on starting fluid, at least for a second I would think.
Straight shooter
I might take it a step further with a pressure test in the fuel rail and also an LED test to confirm signal to the injectors.
Thanks for all of the advice. It ended up being a bad reference sensor. Even though I replaced the old with new, one was still bad.
Have 944, will restore
Good to know. My 85.5 car is doing the same thing and I have been testing everything. Would not even run on starting fluid. I may have to replace both, just for good measure if anything else.
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
