18wheelerbob's Avatar
rear end noise?
Hello again, '87 944 Auto Trans. I started noticing a rattle ling noise in front of the tranny. Is there another flex disc there also?
Old 05-07-2014, 08:51 AM
968 GUY's Avatar
torque converter
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 05-07-2014, 11:00 AM
Rear end noise
Thank you 968 guy.
Old 05-12-2014, 12:28 PM
Have 944, will restore
mazdaverx7's Avatar
Are you noticing the noise at the trans or at the bellhousing that's bolted to the engine?
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 05-12-2014, 12:35 PM
rear end noise
I put the car on ramps, got underneath while it was running and notice no noise behind the engine but the rattling noise in front of the trans. The previous owner stated that I should tighten the bolts on the drive coupler?
Old 05-12-2014, 12:44 PM
After reading the great reply's from everyone and doing my homework on the repair(s) it appears I have to remove everything under the car anyway so why not replace everything that was mention to avoid leaving something out and having to remove everything once again?
Old 05-12-2014, 12:48 PM
