Have 944, will restore
mazdaverx7's Avatar
After repairing the shifter, I can honestly say that I am super pleased with how well it shifts. There is still a minor amount of play and I think I have to work that out at the transmission. Will post pics today of a lot of the progress that I've been making!
85.5 944 Guards Red M456 5spd
06 BMW 330xi 6spd/ 92 Miata 5spd
04 RX-8 Nordic Green 6spd/ 01 MR2 Spyder 5spd
04 RX-8 Brilliant Black 6spd 86 Corvette 4+3
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
Old 10-11-2014, 06:20 AM
mazdaverx7's Avatar
The car has been back in the garage for a few days for the upcoming work.
First thing was removing the tape and paper from the door frame and weatherstripping. Using automotive Goo Gone:
Most of it came off of the weatherstripping bt I'm having a hard time getting it off of the metal:
Also started re-cleaning the engine bay. Got the corrosion off of the cam housing and got it cleaned up:
Old 10-11-2014, 07:18 AM
1983 944 N/A
POPS 83 944's Avatar
Very nice. Keep up the good work
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 10-11-2014, 07:32 AM
Did you replace or repair the shifter ??
Details please.
Old 10-11-2014, 11:34 AM
mazdaverx7's Avatar
After the dash cover was removed..The glue is still on there or it has discolored the dash. Seems as though the glue had been on there for well over a decade:
Old 10-12-2014, 07:53 PM
mazdaverx7's Avatar
Next phase is to replace the ISV hoses and vacuum lines. Long term winter project is a new clutch. But the good news is that I continue to work on the car weekly.
Old 11-22-2014, 05:38 AM
mazdaverx7's Avatar
Got the car back in the garage and am tracing a coolant leak. Looks to be the radiator and from the puddle something on the right side of the engine seems to be seeping. It in my leaks after the car is driven and then parked. A visual inspection revealed no obvious leaks. I'm wondering if the coolant drain plug on the block has a bad crush washer or if its slightly loose. Time to do some digging.
Old 11-25-2014, 06:46 PM
mazdaverx7's Avatar
No updates as of yet. Been working on the ignition failure on my 94 Corvette. Should get this car back in after that for some more work. Been running and driving great though. Its been my daily transportation as long as the snow isn't flying!
Old 12-24-2014, 06:50 AM
What happened to your Fuch wheels in the first several pics, I like them a lot more than the cookie cutters shown in the last pics.
I think that old indash cassette deck might need some attention in the future also.
Old 12-24-2014, 07:45 AM
Frankly my dear....
rhett's Avatar
Originally Posted by ckelly78z View Post
What happened to your Fuch wheels in the first several pics...
I thought I saw they had been fitted to the silver grey '44 in one photo..?
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 12-24-2014, 12:47 PM
mazdaverx7's Avatar
I swapped the Fuchs wheels over to my early 85 and used the 85's cookie cutters on this car because the wheels had new tires. I wanted to use this car over the summer and I had a bunch to do to the early 85, so it was ok that it sat with the Fuchs wheels, which have flat spotted tires on them.
Old 12-29-2014, 09:04 AM
mazdaverx7's Avatar
First wave of new parts came in today! I ordered quite a few more though, so I'm not sure when I'll start in on replacing things. The sooner I sell my 86 944, the sooner I can have this car back in the garage for good.
Old 01-12-2015, 01:32 PM
mazdaverx7's Avatar
Bunch of parts came in today so I'm going to pull the car in the garage and start in on replacing some of them today. I will add pictures as I am doing the repairs!
Old 01-22-2015, 09:36 AM
mazdaverx7's Avatar
Picked up the new nose panel a couple weeks ago and got it installed. Took some pics along the way:
Nose panel removed:
New panel ready to go on:
Old panel on left, new panel on right:
New nose panel installed:
Old 04-14-2015, 01:10 PM
mazdaverx7's Avatar
Took the car for a drive this afternoon and just got back. What an awesome car. I absolutely love it!
Old 05-01-2015, 01:18 PM
mazdaverx7's Avatar
Took some pics of the car the other morning when I got home from work:
Old 05-03-2015, 11:48 AM
mazdaverx7's Avatar
Took the car for a drive today to ensure the speedometer was working properly after I took the cluster back apart and cleaned all of the connections. After I got back I washed the car and at the end of the night, tucked it safely away in the garage:
Old 05-07-2015, 07:33 PM
mazdaverx7's Avatar
So, I ordered a bunch of parts for the car yesterday and decided that I would wash the car again because it had some pollen on it and I wanted the car to be clean when I worked on it when the parts arrived. I pull the car out and notice that the wind is picking up and its getting cloudy pretty quick like. I decide to wash the car anyways...I get it hosed down and get the soap on the car and it starts to pour:
I did what I could to get the soap off and pulled it back in the garage. The rain stopped and I was able to hose the car off the rest of the way and get it back in the garage, though I'm not particularly pleased with the wash job I did. But better than having pollen on the car making me sneeze in the garage:
Old 05-12-2015, 10:38 AM
mazdaverx7's Avatar
Felt like messing with the car today and decided to see what was up with the gas gauge not working. So after some diagnosing, I was led to the sender. Pulled it and cleaned it and began my testing:
Low and behold it worked!!!:
So, I put it all back together and it seems to work just fine now. I'm pretty darn pleased!:
Old 05-12-2015, 12:48 PM
mazdaverx7's Avatar
A couple pics to share after I backed it out of the garage today to get some fresh air:
Old 05-12-2015, 03:11 PM
