Have 944, will restore
mazdaverx7's Avatar
My 85.2 Restoration Project
I've been wanting an 85.5 and up for some time and this one spoke to me as a major restoration effort. So what if it hasn't been on the road in 10 years. Its deserving of a restoration and I will learn a lot by bringing this car back from an inevitable doom. It speaks to me not only because its a 944, but because it has some nice options and the car is mostly unmolested. The initial pics were pics from the guy I got the car from:
85.5 944 Guards Red M456 5spd
06 BMW 330xi 6spd/ 92 Miata 5spd
04 RX-8 Nordic Green 6spd/ 01 MR2 Spyder 5spd
04 RX-8 Brilliant Black 6spd 86 Corvette 4+3
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
Old 05-12-2014, 12:31 PM
mazdaverx7's Avatar
Made it home safe and sound with the car Saturday morning after driving all night Friday. Its now tucked away safely in my garage. I played with it a little and it has a lot of issues which I will post about.
Here are the first few pics of the car once it was officially mine :
Car loaded on the trailer with the pic being taken right after leaving the seller's house:
Pit stop in Columbus on the way home:
Home tucked away safely in my garage (and my son already installed the spare Porsche crest I had in my other 944's center console):
Old 05-12-2014, 12:34 PM
Straight shooter
Lapkritis's Avatar
Good luck!
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-12-2014, 12:38 PM
mazdaverx7's Avatar
Thanks, I was trying to post more pics but the forum would not allow me to do so without mod approval. Once that is done, I will have the rest of the pics up of everything that I've been doing to the car. Its really a well optioned car and a solid platform to start with!
Old 05-12-2014, 12:43 PM
mazdaverx7's Avatar
Started cleaning the engine bay and when doing so, discovered a small amount of oil in the air cleaner housing. Perhaps something is not right with the AOS. I checked the timing and balance shaft belts and both are intact with some deflection. All I wanted to know was if they were in place and to make sure they were not broken. Going to do those fist off. Here are some pics:
Oil in the air cleaner housing:
Pics of the belts:
Engine bay as of right now:
Found this odd metal plate in the box of parts that I got with the car. Oddly enough, the front license plate bracket is bolted to it, lol:
Old 05-12-2014, 05:45 PM
mazdaverx7's Avatar
Finally got the hatch open. Had to disconnect the rods and move them manually and it came right open. Here are some pics of what I found:
This wiring..Maybe went to a car phone at one time? Not sure but it was run to the battery and the fuse box:
A bunch of yuck:
Thought this was kinda nice:
And next to the fire extinguisher, was this amazing piece. I'm not sure if its complete:
Old 05-12-2014, 05:46 PM
mazdaverx7's Avatar
Took a couple quick pics of the interior last night. Will try and post better ones once its not raining and I can push it out of the garage:
Old 05-12-2014, 05:47 PM
mazdaverx7's Avatar
Decided to pull and paint the center caps on the wheels today and paint the rear wiper arm.Thought I'd share a few pics of the progress:
After the red paint was removed and prepped for primer:
In primer:
Painted:
Pics of the car with the center caps removed:
With the center caps painted and installed:
Blasted and painted the rear wiper arm as well:
Old 05-14-2014, 01:37 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I had an antenna on my rear hatch and thought it was for a phone system but later found out it was for a security altert system that called your pager if the car was being broken into. This looks like a good car for restoration.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-14-2014, 12:51 PM
mazdaverx7's Avatar
Thank you!! Where was the control module mounted for that security system?? I'd be interested to see if I have the same thing. The antenna will be off there soon. I may end up replacing the hatch due to heave separation.
Old 05-14-2014, 05:43 PM
mazdaverx7's Avatar
Pulled the fuel rail and injectors tonight for a cleaning. They are the start of the fuel system clean out:
Old 05-14-2014, 10:58 PM
plays with toy cars
sausagehacker's Avatar
If you need any of those bumper pads, PM me. I have a bunch in great condition. Looks like a sweet project!
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 05-14-2014, 11:19 PM
mazdaverx7's Avatar
I do need all four actually..
Old 05-15-2014, 12:22 AM
85.5 944
Chucked's Avatar
sausage hacker, I need a right rear bumper pad for my 85.5.
Old 05-15-2014, 04:06 PM
mazdaverx7's Avatar
Got my little helper on the job. He's been a big fan of my 944's since he was just a wee little guy. Always has to sit in the car and pretend he's driving. Until the tools come out, then its "Dad, what I can fix?" Caught him hanging out in the back seat the other day:
Old 05-19-2014, 11:34 AM
mazdaverx7's Avatar
Good news!! I removed the starter and had it tested at two auto part stores today and both places said that the starter was good. I ended up buying a Napa battery and came home and re-installed the starter and installed the new battery. Just for the heck of it, I cranked the engine over and it cranked normally! No more slow cranking!! I'm excited!
Starter re-installed:
While I was under there, I did notice another thing that needs attention:
Old 05-23-2014, 08:51 PM
mazdaverx7's Avatar
Took a few pics today when I was in the garage:
Original key:
Fuchs are original and in decent shape for the age and neglect:
Damage to the front nose panel:
Engine bay as it currently sits:
Fuel system components being replaced and cleaned. Fuel pump is bad and I plan on sending the injectors out to be cleaned:
Rear carpet is in nice shape still:
Old 06-05-2014, 09:01 PM
mazdaverx7's Avatar
All of the lights are in working order:
Dash warning lights that come on. Not sure if this is all of them or if there should be more:
Cluster lighting seems dim and the lighting seems to be only radiating from the bottom upward:
Last shot before I went to work:
Old 06-05-2014, 09:02 PM
mazdaverx7's Avatar
Ordered all four injector seal kits and pintle caps. Won't be in until Monday though...
Old 06-11-2014, 09:55 PM
There is a nice section in Clarks garage on sorting dashboard lights. The bulbs go dull/fail over time and the silvering off the reflectors flakes off/dulls. Can all be fixed relatively easily ... but you have other priorities
Good luck with your project! I bought a good low km running well maintained '91 S2 and there is enough work for me just keeping up with the daily maintenance You are brave!
Old 06-12-2014, 12:15 PM
