Aftermarket turbo/supercharger mod for a 944 possible?
So i found this diamond of a 944 from an online car sales site:27000 miles driven 2.7 and in a perfect condition,good as new.BUT its the automatic version of the car with only 3 gears so i figured i would need more low rpm torque to it if i would buy it.So is it possible to install an aftermarket low rpm turbo to it?Or a supercharger?Been searching for answers 3 days and not finding any good ones.And i don´t need too much more power,i would like to get something like +40% torque and %10 power to the low rpms to improve acceleration.And the turbo/supercharger should mainly boost the rpms under 4000 so it should be safe to the gearbox?Didn´t find any info from the gearbox either...
Porsche 911 3.2 G50 1987 Mods:Clubsport RS wheel,Designtek exhaust system and a wiesmann lizard sticker which gives + 10bhp |
Since its a 2.7, that could be the 944S 16V engine. Luckily there are kits for the S and S2 engines:
928 Motorsports - Porsche® Performance Parts - Mods for 944 S2 Install 928 Motorsports - Porsche® 928 Performance Parts - Porsche® 968 STAGE 1 SUPERCHARGER KIT 928 Motorsports - Porsche® 928 Performance Parts - PORSCHE® 968 Stage 2 SUPERCHARGER KIT Otherwise for a 8-valve engine its certainly possible to go your own route, but you'd have to build it from scratch by adapting a turbo or supercharger to the engine by fabricating an exhaust manifold or factory 951 parts (turbo) or brackets and pulleys (supercharger). Either way the ECU would need to be replaced (MegaSquirt) or reprogrammed (chip swap). A 5-speed swap might be slightly easier, but I'd drive it first before planning on a bunch of changes.
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
the automatic in that car is not up to handling much more torque.
that particular supercharger kit, and the fact that it would not work properly on the 968 (proven countless times by those who have tried) is exactly why i finally went forward with mine. i do see that he has now incorporated a number of my design features though, to try to make it work better. unfortunately i do not make a kit for the 944 as yet. the mounting and all that is essentially the same, so it could be done, but the tuning would be entirely different. as yet, nobody has wanted to pony up for a kit on a 944. if somebody wanted to tune it themself, they could probably you could get the mounting kit and have at it. Last edited by flash968; 05-15-2014 at 07:30 AM.. |
The automatic is VW-based and is capable of being modified to make it better:
924Board.org :: View topic - Auto tranny hot up thread
from what i understand, it still has the flex dampener, which is the weak point. we have that issue on the 968, even in stock trim. that is why i did not want to develop a kit for the tiptronic. i have one out there being tested right now, on a new flex dampener. even at stage 1 though (275hp) you can feel that it isn't terribly happy. not sure how long it will hold up to the beating of rapid gear shifts from stomping on the gas pedal.
replace the damper with a clutch disc. This is also a documented modification to replace broken or failed units.
plays with toy cars
+1 on just doing a 5-speed swap. I bet you can pick up a NA trans for $150
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
...almost there.
Straight shooter
4Cyl direct port, wet shot, nitrous oxide can now be had for well under $900.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Straight shooter
I suggest this with tongue in cheek but I'm half way serious.
AFM #725
Nitrous
cheaper to go LS...
dolor et pavor Copyright |
Straight shooter
...not in Finland.
^^ that sucks.
How much fab can you do?
Writer/Teacher
It's funny: 10 years ago, if someone posted on this site with a turbocharging/supercharging/"getting more power from a NA" thread, the default response was always "you're better off just buying a 951". I wonder to what to attribute the sea-change shift in philosophy?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
1989 944S2 with a 968 motor swap. Mostly Awesome. 1988 944S, secret goodies. *Sold* 1987 924S, parts car (hit by a texting driver). |
this has proven to not be the case, though not a bad idea. considering everything bolts on to the non-turbo bodies, why not? |
