Oil in Intake
Hello,
I started to notice oil leaking out of my intake. I have removed my intake and 'J' boot. Oil is everywhere through the system. I felt for play in the turbo and there is no play. Is it possible just to blow the seals? Or may I have another issue?
Old 05-24-2014, 01:40 PM
944tothefloor's Avatar
AOS seals separate the air and oil. Probably those are blown.
Old 05-24-2014, 02:16 PM
Proprietoristicly Refined
John_AZ's Avatar
Yup ^, easy fix.
Remove the intake.................remove the AOS...................replace the 2 seals and maybe the oil dipstick "O" ring.....................WYAIT.................... .....rebuild the throttle body...................replace all clamps on hoses under the intake and use new Oetiker clamps or non-perforated clamps.................replace old hoses if necessary....................replace vacuum lines and have new "T"s available.....................clean/reseal the injectors..................just to mention a few odd jobs.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-24-2014, 02:58 PM
