Dr944S2's Avatar
Video: Repairing DME Relay
Hi,
a broken DME relay is one of the most common failures of the Porsche 944. The video shows how to check the relay. In most cases a broken soldering point in the relay is the reason for the male function. The video gives you a tutorial how to solve the problem:
Porsche 944 Repairing DME Relay - YouTube
The video has a German soundtrack, but English subtitles are added to YouTube. If you don't see the titles by default, watch the video directly at YouTube and press on the subtitles button below the frame.
Enjoy it,
Jürgen
Old 05-26-2014, 02:33 AM
Yet again a very nicely done, and informative video.
Thank you Jürgen.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 05-26-2014, 03:47 AM
Send a message via Yahoo to bigyagi
dme relay
very timely. i had my dme relay fail about a month ago. i had a spare one so fitted it, and away i go. less than 200 miles, and the spare one failed, almost leaving me stranded.
luckily, i had my friendly spark, remove all solder from the original relay, and re-do all the soldered joints. no problems now.
back in the day, the solder they used, was a different mix, and you would get all kinds of problems, like cracks in the joint (both my relay failures), or cold solder joints after time.
its not a hard job to remove the old solder, and re-do the relay with modern solder , which should last for a very long time.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 05-26-2014, 04:53 AM
BlueStwo
Phantoms's Avatar
Thanks! I subscribe on youtube and all of your 944 S2 videos are very helpful.
90 S2 Coupe- Baltic Blue Metallic #110/449
Old 05-27-2014, 06:36 AM
Tags
dme , fuel , ignition , pump , relay
