944tothefloor's Avatar
"Gross" failure of SMOG test! Going for the retest soon!
Thanks in advance to everybody! I am a frequent lurker here though I am only beginning to post more.
Well, I failed smog in a scary way, and it's not even Halloween yet!! D:
I got 'gross polluter'.
I need to go back in tomorrow already to pass and to make sure I can keep her (1986 951; 112,000k mi) on the road. Engine was hot for the test.
I didn't take out my 2 autothority chips, buy I will for tomorrow. I'll put acetone in the tank I guess. What else? Does the data below suggest a bad cat?
I'll be responding to ideas/questions in the thread ask me anything and thanks in advance to everybody! Please help...
Old 10-16-2012, 02:39 PM
Proprietoristicly Refined
John_AZ's Avatar
Hello "Gross Polluter"
Rogue_Ant on RL has a few answers.
Check your FQS settings.
Here are the links that may help--CA focus:
Failed CA smog... - Page 3 - Rennlist Discussion Forums
Seriously failed smog test - Update 6-/18 - Rennlist Discussion Forums
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-16-2012, 03:52 PM
Thanks, John. I just read both of your posts.
I'll add that I just did a major tune-up a month ago. Plugs, oil+air+fuel filters, oil, dist. cap, rotor
Old 10-16-2012, 04:11 PM
porscha
matty89's Avatar
is ur Airfuel meter drilled meanning is there a door inside ur "MAF" or barndoor air meter
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 10-16-2012, 04:15 PM
AFM #725
Gawernator's Avatar
You live in California but aren't getting a CA smog test? I don't get it.
I wonder how my car will do now, with all my repairs and upgrades. That was immediately after I had bought the car and had the 26 year old cat welded back on. The cat had only been on for an hour lol.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-16-2012, 04:31 PM
flash968's Avatar
Old 10-16-2012, 05:01 PM
Rogue Tuning
Rogue_Ant's Avatar
Way too rich... definitely take out the APE chips. Additionally, the APE chips generally required a 3bar fuel pressure regulator - stock chips need the 2.5bar unit. Otherwise you will be adding ~10% more fuel, which you definitely don't want.
How long did you drive/run the car before the test? If you can put your hand on the tailpipe, then it isn't hot enough...
A good possibility that your cat isn't working very well too.
John is correct, check your FQS position. Your first test is so far off, that it is hard to even use it as a "baseline". Start with the FQS fully counter-clockwise (position 0, the factory-shipped position). Furthermore, a California car should have the "coding plug" installed, which tells the DME to use a more aggressive closed-loop feedback.
Also, how old is your O2 sensor?
-Joshua
www.RogueTuning.com
Old 10-16-2012, 10:28 PM
flash968's Avatar
in case nobody figured it out, the image above should have hinted at a dead cat
Old 10-17-2012, 07:05 AM
I'll try to get a new cat + o2 sensor tomorrow. No records of a change for either. This is a bummer because I don't have time to do my own work. Any ideas on cost at a shop?
Also, where is that FQS control? Thanks guys, for your help.
Old 10-17-2012, 06:28 PM
In the Fires of Hell.....
kdjones2000's Avatar
FQS is a little rotary switch located on your DME in the passenger footwell. Different settings are for richer fuel mapping, timing, etc.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-17-2012, 06:54 PM
gmorken's Avatar
I got a new universal cat installed for less than $200 at a reputable shop... O2 sensor was fine and not replaced. Multiply my Tennessee cost by 150% since you're in California.
1985/2 944 Alpine White, Fuchs
Musik Stadt chapter of PCA
Old 10-17-2012, 06:58 PM
AFM #725
Gawernator's Avatar
CA cat = about $200 plus maybe $100 to have it welded on.
Old 10-17-2012, 07:43 PM
Right on the nail. Went to the shop today. Quoted about $300 for new Ca cat to be installed along with a new Ca o2 sensor for $70.
Next I'll use the rest of the ideas here.
Old 10-18-2012, 08:10 PM
Would it be cheaper to move to New York? There is no emissions test here for cars without IBDII and only a really quick $10 inspection for cars over 25 years old!!!
Old 10-19-2012, 04:58 AM
The car passed, amazingly! And the numbers were crazy good! Thanks to everybody for helping.
The only things I did were remove the APE equipment (klr and dme chips, and modified banjo bolt) and had a new cat put on. No new o2 sensor! Everything else I left the same. Also, I went for 2-hour drive to prepare the engine. Right before the smog test, I drove at ~4k RPM for about 2 miles to bring the engine to a high temperature.
The smog guy couldn't believe it passed! Looks like I'll be avoiding a $200 parking ticket!
Old 10-19-2012, 07:19 PM
Banned
Alex, pls give me a call to finalize my long overdue refund. Does anyone know this seller?
Old 06-07-2014, 01:55 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Parking ticket? Glad you got past the evil clutches of the government regulators.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-07-2014, 06:12 PM
jwmc1's Avatar
Move to Michigan!!!
John
Old 06-10-2014, 08:39 PM
Banned
Alex, I thought u wanted to pay me what u owe. It's important for pelicans to know what kind of guy u are. It's up to u if everyone knows what a schmuck u are or a good guy. Right now, I say schmuck. Make me change my mind.
Old 06-11-2014, 06:29 PM
jwmc1's Avatar
What is this all about?
John
Old 06-11-2014, 06:34 PM
