LinkBack | Thread Tools | Rate Thread |
That Guy
You can usually get the broken threaded piece out with a screw driver, a Dremel can come in handy to make a slot in whatever is left in the radiator to aid in this.
Jon - San Diego PCA #516 1988 Granite Green 911 3.4L 2017 Reflex Silver Mk7 GTI Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1, 1997 E36 M3, 2003 E39 540i |
You shouldn't have to remove the radiator to remove the broken off piece. And a screw driver or a picket knife should be enough to twist it out.
I recently had this same issue. I was able to use a flat (not Phillips) screwdriver to get the piece out. I searched through my selection of screwdrivers until I found one that just wouldn't fit into the hole. With a little pressure to push the screwdriver into the hole a small amount, I was able to get the piece out. Don't force the screwdriver in more than needed, as it will expand the part and make the threads tighter and thus more difficult to get out. The original part is not that tight a fit on the threads, so with a little patience, you should be able to get the part out.
Also, if you have a thread out (or what ever it is called), you might find one of these the size that will work. |
curtisr
Now that's a good idea!
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (a work in progress and on course to become my track car) 1987 924s Garnet Red 1982 928 Silver (sold) |
Thanks for the replies! That is very encouraging.
Happened to me. Actually used an ez out. I panicked when i discovered it was cracked and the nipple just broke off with the threads inside. The piece came out easily.
Broke the drain plug on the 951, same deal with removing it.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
I finally got back to this this evening and using the procedure you all suggested the still-threaded-in part of the fitting came right out with no issues at all. I used what I think you all are calling an "ez out" (I've seen different things called that - in my case a short bit with a sharp, sightly curved, left-handed straight-blade like head that I turned with a small flat ratchet). The ez out was short enough that I was able to get it, and my fingers to push on it, in without even having to remove the coolant crossover tube (the car is a turbo). So much thanks.
Thread Tools | |
Rate This Thread | |
Tags |
944 turbo , 951 , plastic , radiator |
