Wrench Therapy Inc.
Exclamation Rear Hatch Advice
Hello my fellow Pelicans. So I removed my rear hatch for the glass separation rehab and I believe I am in a bit of a bind. I need some procedure or part help. I got the frame removed in short order without bending the frame or breaking the glass, but the rubber seal that surrounds the glass is a bit tatty. The seal pulled off and stayed in the frame in numerous pieces across the top of the hatch where the hinges are. As it stands now I do not have a continuous seal surrounding the glass. What do I do? Is there a replacement seal and if there is what is the part number or where to get it? I assume Pelican has this part, but looking for advice from someone who has been in this situation before. On a side note the 83 base N/A will be going to paint in the first part of June to get her a fresh new coat of Zermatt silver. Can't wait and I will post photos. I appreciate all help in this matter.
Old 05-10-2014, 02:37 PM
There are several post on RL regarding this. The "seal" you are speaking about is the sealant that is used to seal the glass. It is not a gasket.
Old 05-10-2014, 07:08 PM
Wrench Therapy Inc.
Hatch advice
So do I remove all of the old seal and just have bare glass to remind to?
Old 05-10-2014, 09:54 PM
You really need to search for the thread on RL for this job.
There is all kinds of specific info you need to know.
Old 05-11-2014, 05:45 AM
alan6272's Avatar
I did this as well and yes remove all old seal. I used black rtv sealer when I reattached mine 4 years ago no problem and I have new struts as well. I googled this project and it led me to step by step procedure. I really think it was on here. Try looking into clarks garage for this..
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 05-11-2014, 06:11 AM
alan6272's Avatar
944 Rear Hatch Glass Repair
catalina22 sold
baja ski boat sold
my toys
Old 05-11-2014, 06:14 AM
Wrench Therapy Inc.
Thanks guys. I will be tending to that glass today.
Old 05-11-2014, 07:43 AM
Have 944, will restore
mazdaverx7's Avatar
Keep us updated on how everything goes!!
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 05-12-2014, 12:44 PM
kwikt 911's Avatar
Which adhesive are you using?
Old 05-12-2014, 02:19 PM
alan6272's Avatar
I used 3m rtv black silicone worked great been years now
catalina22 sold
baja ski boat sold
my toys
Old 05-13-2014, 04:36 AM
Wrench Therapy Inc.
Sitka Move It cold bond professional windshield installer urethane based adhesive. It uses two types of Sitka primers for both the glass and the metal frame. Glass man said this stuff is not playing around. He said it makes the 3m stuff look like elmers glue. We will see and I will report back.
Old 05-13-2014, 06:15 AM
1990 944S2
Send a message via Skype™ to ChrisRL
+1 on the Sitka stuff, the guy who installed my 944 windshield was using it, swears by it.
84 944 gold sold
90 944S2 black current DD
89 735il white fixing
89 GL1500 white restoring, 01 955i S3 black current DD
01 955i Sprint brg customizing, 89 955i Daytona gold restoring
Old 05-13-2014, 06:19 AM
Registered n00b
RennsportKC – 944 Hatch Reseal RennsportKC
RennsportKC – Porsche 944 Rear Hatch Seal Part XXISCSV: RennsportKC
Cheers
'88 944
'88 Turbo S
Old 05-13-2014, 02:20 PM
Where can you buy this from? All I seem to find is MSDS sheets on this stuff.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 05-13-2014, 04:31 PM
Wrench Therapy Inc.
you can back from a place called glass Services Incorporated in Shreveport Louisiana. the guy I need to talk to is in the automotive glass department I don't remember his name. it ran about $15.95 per tube in that scene that it would do one large window
Old 05-14-2014, 09:57 PM
mazdaverx7's Avatar
I might have to be in contact with the company. One of my 944's needs a hatch reseal!
Old 05-18-2014, 01:02 PM
Hi,
Any updates available on this?
Silver '83 944 - RIP 12/12/2014
Old 07-01-2014, 09:10 AM
Wrench Therapy Inc.
Frame and glass are SOLID. I won't know if they will separate after the hatch is installed and the struts connected. If it does, then there is no adhesive on the market that will every hold it. The Sitka Move-It is way stout. For attest, I stuck a piece of car glass (tempered) to a metal frame piece from a junkyard and I cannot move it at all or pull the glass off the adhesive after I intentionally broke it . I will update when car is finished with paint and hatch reinstalled and subjected to Louisiana heat and roads. If you do not know, Louisiana has the best low bidder construction firms in the country and the worst roads in the country as far as smoothness, durability, and general state of repair. As far as paint report, she is down to the wet color sand and cut and buff. She looks like wet ice. I will post when reassembled with all fixtures and trim.
Old 07-01-2014, 12:08 PM
