ran then died -- no start - no spark
no start issue on a 951. full post on that forum below. just in case someone here has ideas.
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/818786-ran-then-died-no-start-no-spark.html |
Have you gaped the reference sensors correctly? If so I would borrow or purchase a known good ECU and give that a try. Seems like you have checked and done a good amount of trouble shooting already.
actually I regapped the sensor per Clark's garage.
tac inop, so tested with O scope. both speed and ref sensors generate nice signals, verified at the DME plug. keep those suggestions coming. |
I would try a good working computer next.
bad coil.
on other post, I commented I had verified 12V to both coil leads. but had not fully tested as I could not find my test light last weekend. found test light and first thing I checked was the coil. NEW coil, so not at the top of my suspect list. going for a nice, long drive this morning. |
I have never had a bad coil. It always came to something else. Good cheap fix.
See '944S electrical post' for my suggestion with engine ground. Pm me if needed, later...
