Fuel or gas from head studs
Hi guys, I have an 86 944 N/S. I have a leaking fuel injector at present that has leaked an amount of fuel over the head, however I have noticed that two of the head bolts/studs near the spark plug sockets are bubbling exhaust gas through the fuel I am assuming. Or would it be possible to be bubbling a combination of fuel and gas from here?? The engine shows no other signs of having a head gasket failure.
Can anyone shed some light on this problem.
John
Old 07-03-2014, 02:55 AM
Bradical's Avatar
I hope you have a fire extinguisher near by. The boiling point of gasoline can be as low as 100deg at atmospheric pressure, it could be the temperature of the head causing the fuel to bubble I would think.
Old 07-03-2014, 04:37 AM
Back from Beyond
^+1
Old 07-03-2014, 06:35 AM
The fuel injector body may be cracked and leaking. Or it may be a leaking o-ring or fuel line. Don't take any chances on an engine fire. Don't drive it until it is fixed.
Old 07-03-2014, 01:18 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest cracked or warped head or head gasket, pray for the latter...
Kayjay,
Wow, fortunate to catch these any serious damage...
Keep us posted..later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 07-04-2014, 08:21 PM
Volhv's Avatar
I had an injector do the same thing. Replaced them with early ones since they are easier to source.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-04-2014, 10:52 PM
Autocross/Hillclimbs
Note that early vs late have different flow rates. I had one start leaking the same way, everywhere, from the joint between the tip and body of the injector. Replaced them all with used ones from a wrecked car
2x 1984 944 N/A; 1988 951S Silver Rose; 81 VW Rabbit Diesel; MK4 VW R32
President - Bridge City Autosports
http://www.bcautosports.club
Old 07-07-2014, 04:57 PM
Volhv's Avatar
They sure do, but early vs late fuel pressure regulators adjust to different pressures, therefore if you split the difference, they end up being about the same.
Fuel Injectors
Old 07-07-2014, 06:49 PM
not to disrespect the boards sponsor but I like the five-o-motorsports offerings. New stuff and reasonable prices. I have put them in an old 3.9 rover and it really brought the engine to life with a better spray pattern. I have a set in my straight 6 merc and my long term fuel trim settled at -10%. More power and better fuel economy.
1986 PORSCHE 944 L4, 2.5L, A, GAS Fuel Injectors
Old 07-08-2014, 07:56 AM
