Garage sale
Stock intercooler, good condition and no dings-- 100
Stock hard pipes, small dings -- 40
working ISV-- 40
86 951 DME, known working, with APE stage 2 chips-- 260
86 951 KLR, known working, with APE stage 2 chips--260
turbonetics replica #8 hotside, machined for a stage 3 wheel--- 150
Early N/A alternator--- 35
Pair of stock N/A front springs -- 20
2 pairs of stock spring top hats--10 each
pair of 86 turbo strut top mounts with good bearings--40
New set of late offset power inner tie rods, never installed and still in plastic --60
New set of late offset power inner tie rods, installed and used for about 1 week on the street before I decided I wanted to convert to early offset --45
Rebuilt N/A clutch fork with new bearing-- 100
set of factory 86 turbo M474 koni adjustable rear shocks, usable but probably need a rebuild--30
Set of factory 86 turbo M474 koni adjustable struts, one is good, one needs a rebuild, or turn these into double adjustables-- 100
Working 86 951 AFM-- 100
Used 2.5 bar FPR--15
factory 951 fuel pressure damper--25
working ignition coil--30
3" Adapter for cone filter for AFM-- 20
Used but working cycling valve--35
headlight motor--40
headlight bar with linkages--25
Complete pair of rear seat belts--100
Cam tower with early N/A cam-- 125
Bosch ignition control module off a 944S--20
2 late car cooling fan relays, 70 ea
Used A/C drier--35
Brand new front cam cover with new gasket, never installed--50
2 pairs of used parking brake shoes and springs---20 each
4 fuse tester relays---10 each
2 Distributor caps--15 each
2 distributor rotors--10 each
3 OEM spark plug wire sets-- 30 each
Crank/alternator pulley--25
Also have all the power steering lines and tank, let me know what you need!
edit: added more stuff
Old 07-04-2014, 01:17 PM
added more stuff. I'm open to offers for any of this.
Old 07-12-2014, 11:44 AM
updated
Old 07-19-2014, 09:34 AM
Have 944, will restore
mazdaverx7's Avatar
Would the ISV fit an 85.2?
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 07-19-2014, 12:32 PM
Just thinking out loud
mattdavis11's Avatar
35 for a used drier? That has to be a joke. I can buy a new one for $3.37.
91 FJ80
84 Ram Charger (now gone)
Old 07-19-2014, 01:09 PM
You're a joke, a new one from pelican is 60.75 + shipping and that isn't OEM. I appreciate constructive criticism but you are being an *******. Sit down.
Old 07-19-2014, 05:27 PM
Yes, its an ISV for all late 944.
Old 07-19-2014, 05:31 PM
No, I am not a joke. I can buy a new drier for $3.37 five days a week. Who would buy a used one?
Move your parts in the for sale section next time.
91 FJ80
Old 07-19-2014, 07:53 PM
Well, then enjoy your cheap parts. Several people got in touch with me about it so I dont think I'm being unreasonable. If you don't want the part, don't inquire about it.
Old 07-19-2014, 08:45 PM
I didn't inquire about a damned thing. Hopefully, I opened some eyes. A used drier? Really?
Peddle your parts in the right section next time.
91 FJ80
Old 07-20-2014, 05:29 AM
I am looking for a museum quality set of spark plug wires. Can you post pictures of the ones you have for sale?
Old 07-20-2014, 06:01 PM
I'm not sure what that means...sounds like you need a set of NOS factory wires. Mine are all in perfectly good shape but uses, which pretty much means not museum quality. Sorry.
Old 07-20-2014, 06:34 PM
It is for a 944 frame off restoration. I also need an original ignition rotor for the project that has no more than a 50 micron wear on the contacts. Do the rotors you are selling meet this specification?
Old 07-20-2014, 07:56 PM
...50 micron wear? Right....Sorry if I'm wrong but I think you're trying to play a game here. funny joke.
These are used parts people. period.
Old 07-20-2014, 08:45 PM
plays with toy cars
sausagehacker's Avatar
Doug, want me to send you my micron calipers?
I have some NOS muffler bearings and timing belt relays if anyone is interested.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 07-20-2014, 09:29 PM
Bradical's Avatar
Are the timing belt relays OEM? Because I have never heard of them and I am positive my car doesn't have them. Are they necessary for the operation of the car? I think the previous owner did a timing belt delete because I opened the belt canopy and there is nothing but two remote-resi headlight fluid canisters, no camshaft flapper rod or anything
Old 07-21-2014, 06:30 PM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
Muffler bearings!? So rare!
Hi Doug, PM sent.
I will follow up in your Parts thread..
Garage sale, lots of parts inside.
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 07-21-2014, 07:55 PM
Patrick
pfarah's Avatar
Not wanting to interfere with this spirited conversation but shouldn't this discussion be posted in the used parts section of this forum? Just checking...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-21-2014, 08:01 PM
