oil leak
I have an oil leak and I cant find where it come.
its on the passenger side near the oil filter.
i already change the cam seal but still leaking.
i suspect now the two balancer shaft seal.
have any idea......thanks
Old 07-22-2014, 01:49 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
If you want to be sure before you start tearing things apart, go to Autozone or somewhere similar and buy the fluorescent dye tracer kit. They're cheap. Pour some dye into the oil and drive the car a couple of hundred miles and then, using the magic flashlight and glasses, you'll easily find the leak. Tip: before you do this, high pressure or chemically clean the front of the engine so it's easy to find the source of the leak.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-22-2014, 03:03 PM
unindicted co-conspirator
looneybin's Avatar
it could be coming from the oil pressure sender
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-29-2014, 12:46 PM
AKCJ's Avatar
I have a similar oil leak. Seems to magically appear on the bolt heads that hold the balance shaft on the pass side, behind and below the oil filter. I do not think it's from the oil cooler or from the OPRV. I keep cleaning it up and looking again but it's just on about 3 or 4 bolt heads?
It's right behind the oil press sender so maybe that's it. May have to change it out and see.
Thanks loony.
Red 83 944
Old 07-30-2014, 03:32 PM
