How to get the CV Boot clip on tight?
Hello All,
Thanks to this forum I was able to replace my worn CV Joints. After getting everything back together I did an inspection and noticed my CV boot clip isn't as tight as it should be. Can someone please share this technique? Is a tightening tool used? Good source for newer and improved cv boot clips? T.I.A. |
Yep, there's a tool for that...
Try googling "CV JOINT BOOT CLIP TOOL" :) |
Can I borrow it when you are done with it? :D
Here's what I use: http://www.amazon.com/Lisle-30800-Boot-Clamp-Pliers/dp/B0002SREPY/ref=sr_1_2?ie=UTF8&qid=1407432967&sr=8-2&keywords=cv+clamp+tool
Free for loan in Colorado. |
You could check AutoZone. They loan out a lot of tools for free.
Thank you Everyone!
I was thinking my piano fingers just aren't strong enough to squeeze this tight enough. Now I see that even the big manly man hands of this forum use a tool for this! Sure Bradical, I'll pass it on to you :) Thanks again! |
