Have 944, will restore
mazdaverx7's Avatar
Cam Gear Removal
Looking for some tips on removing the camshaft gear. I want to replace all of the seals on the cam box as it looks as though its leaking in the front behind the cam gear. I removed the 8mm bolt that I thought was securing it to the camshaft but it still wont't budge off of there. Any tips of getting that thing off?
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 08-08-2014, 11:34 AM
mhariush's Avatar
Did you remove the woodruff key? The gear sits really snug, you have to try and jiggle it loose and put equal pressure on both sides of it and pull.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-08-2014, 11:49 AM
mazdaverx7's Avatar
Thank you. I will give that a shot!
Old 08-08-2014, 11:59 AM
You will not be able to remove the woodruff key before removing the cam gear.
The gear can be a real bear to remove, I have seen some posts where other people used a two and sometimes three jaw puller to remove the gear.
When you are putting it back together a little anti-seize will make life much easier if you ever need to remove it later.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 08-08-2014, 02:24 PM
When you said you removed the 8mm bolt I thought you were talking about the triple-square that holds the gear to the cam. Sorry about pointing you towards a puller with that bolt still in place.
1981 924 Turbo
1987 N/A Auto
Old 08-08-2014, 03:34 PM
mhariush's Avatar
mazdaverx7, when you say the 8mm bolt, you mean the cheesehead bolt yes? That's how I read it too. You have to loosen that and counter with a wrench on the carrier behind it...careful, the cheesehead strips as easily as, well, soft cheese... and the engine is easy to rotate if you're not countering enough or too much...
And yeah, woodruff key you can't remove before, that holds the gear in position, don't know what I was thinking there...thanks jeffrsmith
here's a diagram of the camshaft and parts
Edit: I see that someone came up with the solution on rennlist, and I now see what you mean about the 8mm bolt. I haven't wrenched on the 8V car for so long I forgot about that sleeve thingy. The 16V doesn't have that. But be very careful with the cheesehead. Buy a new one here on pelican to put back in cause those things are a paint. And they're cheap to replace when you can. I use a long adjustable wrench and wedge it against the chassis or wherever it may fit to counter the triple square bolt. And use a breaker bar or a long metal tube on your wrench to loosen the cheese head so you can be in control. Easy to slip. Make sure you bang the cheesehead socket into the bolt tightly.
Old 08-08-2014, 06:32 PM
mazdaverx7's Avatar
Thank you for all of the great advice guys!!! I really appreciate your input! As of right now, I'm not worried about turning the cam so that the valves hit the pistons. This is where I'm at with the cam box:
because I bought the car with 8 bent valves, a complete going through of the cylinder head was necessary, which is what I installed two nights ago:
I'm concerned about the oil seepage out from behind the cam gear on the cam box. I figure I may as well replace all of the seals while I have it apart.
Old 08-09-2014, 04:17 AM
Back from Beyond
Sometimes no matter how careful you are that cam bolt strips. It's gotta be replaced anyway (it's a stretch bolt), so you could just drill its head off.
Speaking of heads, nice work!
Old 08-09-2014, 06:21 AM
