don't forget that there is a loss factor when measuring rear-wheel HP. The loss-factor value is a source of much debate but my own conclusion is that you lose 15% throught the drivetrain. I've read loads of postings/discussions on this and it always seems to swing to that value for 924/944/968 models. So a 968 stock motor generates 236 BHP at the crank, multiply by 0.85 and you get ~200 at the wheels. I had my own S2 dynoed ( http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=15&t=011134 ) the same day as a 968 and he got 199 RWHP which is right in line with a 15% loss factor. The Excellence issue which had the 944S conversion to 968 motor was #99, 02/2001, "Second Wind" - Installing a 944S2 engine into a 944S Karl.
Previously: 1991 944 S2 Currently: Something from München... http://www.weissach.net/ |
The car looks great and the 968 engine was a sick addition, will the 968 engine bolt up to a stock 944 transaxle config? thx-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
I myself just rebuilt my 944S engine, but like the idea of the 968 swap. Other than the engine itself, did you have to replace anything else under the hood? Did it pretty much line right up and drop in? I'd be interested in seeing how hard a swap like that would be.
Can anyone think of any issues that might cause with preformance (i.e. transmission, exhaust, etc)? -S
------------------------------------------------ - Sternn - 944S - Project Car - - Web Master & Used Part Guru From - www.stuttgartparthaus.com ------------------------------------------------ |
Nice looking mod!
Hmmmm, I could probably buy Overkill's 944S for $500, and then all i need is a 968 engine.... -Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
HA HA HA,....
{1987}944S - (SOLD). |
....... YEAH RIGHT!
Hi, I was linked to this thread from Rennlist. I'm about to do a similar swap, a 968 engine into my S2 Cabrio. I'm using the 968 DME, bellhousing, clutch, torque tube and air meter. I understand however that I need to make some modifications to the DME wiring? Does anyone know the details? I think the tach hookup might be different too.
Thanks for any advice, BTW the 944S/968 swap looks cool. -Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
