MDH MDH is offline
AC compressor clutch
Can the ac compressor clutch be changed without removing the compressor?
The reason I ask is the ac blows cold, BUT it sounds like a herd(?) of piglets squealing.......even at times when ac is off.
If I spray wd-40 into the clutch it quiets....for a few seconds.....
Maybe it's time for ac delete.
1988 924S
It's still cheaper than psychotherapy...................
Old 08-13-2014, 06:50 PM
Just thinking out loud
mattdavis11's Avatar
You will probably need to at least unbolt it, but you shouldn't have to discharge the system. Just a tip, unless you have an impact, air or electric, gun you will want to remove the outer bolt before you unbolt and hang the compressor to remove the clutch assembly.
I remove the compressor entirely because it is easier that way, and I replace the shaft seal while I'm at it.
91 FJ80
84 Ram Charger (now gone)
Old 08-14-2014, 03:55 AM
Proprietoristicly Refined
John_AZ's Avatar
Sure.
AC Compressor Clutch Coil Replacement On Car DIY.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-14-2014, 04:49 AM
MDH MDH is offline
Thank you......now to go clutch shopping......and maybe new tools!!
1988 924S
Old 08-14-2014, 06:47 PM
Bradical's Avatar
For what it's worth, if it is squeeking really bad when the clutch engages it might just be the belt. I thought my clutch was bad too because it screeched when the compressor engaged, but after I did my belt maintenance i noticed the belt was a little dry-rotted. New belt, retensioned and no more problems. Maybe start there?
Old 08-14-2014, 06:56 PM
MDH MDH is offline
Belt appeared good and correct tension......but, maybe I'll change it anyway..
It's a couple years old.
1988 924S
Old 08-14-2014, 07:02 PM
kens_74_911s's Avatar
clutch
The Pulley has a dual roller bearing pressed into it and held in with a retaining ring. If you take the Ft clutch disk off ( center bolt) and remove the belt then you can evaluate the bearing . If necessary access the large snap ring to pull the pulley off the housing the clutch. The clutch solenoid is after that, attached to the Pump Body and probably not bad in your case.
There are 3 main parts attached to the AC Pump (not including fasteners and retaining rings).
Ft clutch face
Pulley with bearing
Clutch Solenoid
After clutch face is off you can evaluate the bearing before its removed.
bearings are available and can be replaced without a large press if you have a large socket or metal ring to press it back in on the OD.
Some Images of clutch parts off a bad compressor. I have these For sale or parts from them LMK.
another set of clutch parts
Compressor with clutch parts removed, shows hub that pulley bearing fits over.
Below what can happen when bearing seizes or bearings get so bad that it destroys the FT aluminum hub on the compressor - This is off my BMW. This happened when bearing got to loose lost a few balls then locked up. This took out the belt that also was wrapped around water pump-needed a 30 mile rollback tow home.
Attempting to replace pulley/ bearing without removing the Pump. The bearing ended up destroying the Compressor Ft casting. Note the BMW compressor splined input shaft VS keyed shaft on the Porsche compressor.
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 08-15-2014, 09:17 AM
MDH MDH is offline
Thanks again....
All this info is a real help to a guy who
has to remind himself, occasionally........
lefty loosey and righty tighty.......................
and maybe new tools!!!
1988 924S
Old 08-15-2014, 04:51 PM
