-   -   Can't Remove Control Arm Bushing Liners (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/826276-cant-remove-control-arm-bushing-liners.html)
Chunkerz 08-20-2014 05:49 PM
I'm trying to remove the liner things for the front control arm bushings so I can install my new Elephant Racing bushings. The new bushings came with directions for removing them and these ****ers aren't going anywhere. I've tried pounding them out, heating up the control arm then pounding on them, soaking them in penetrating oil for a few days then pounding on them, but nothing works. The directions say that I can cut a slit in them, so I tried that, but this is some tough metal. None of my metal blades can cut this stuff. Has anyone else removed these before? If so, how did you get them out?
Thanks,
Jeff
flash968 08-20-2014 05:54 PM
they are a real bear to remove. you really can't do it with the control arms in place, so i hope you aren't trying that.
they really have to be driven out. there are two halves to the bushings, one pressed in from each side.
Chunkerz 08-20-2014 06:03 PM
I've been doing it in my vice. I'll stop by Home Depot and see if they have any diamond tipped blades for my hacksaw. Even with one of those I doubt I can cut these things. My heavy metal cutting blades have only made scratches so far...
veleno 08-21-2014 12:54 AM
Pic? I'm a visual learner :)
zedsn 08-21-2014 04:07 AM
If the rubber bushings are stuck in there and the control arms are already off the car I had success with my 300zx with burning the rubber and melting it with a torch and map gas. That was the only way that I was able to remove mine.
Chunkerz 08-21-2014 04:27 AM
I'll get one after work.
The rubber bushings are long gone. The metal sleeves they used to be contained in are what I'm trying to remove now.
speedysprocket 08-21-2014 07:34 AM
I just used a hack saw blade i had and some time. Cut through one side and knock it out, then the other half should be eaiser to press out. It was not more work than I expected.
zedsn 08-21-2014 09:15 AM
Can you get a small diamiter metal cutting rasp in there with a dremel and just gently cut one it down the middle on each side and gently pry it together when cut through and remove that way?
Chunkerz 08-21-2014 11:07 AM
I'll pick up some fresh cutting blades at Home Depot and try again.
With a dremel I wouldn't be able to cut vertically. There isn't enough room.
Nufy 08-21-2014 02:19 PM
Big Drill bit ?
Chunkerz 08-21-2014 06:45 PM
Originally Posted by Nufy (Post 8224610)
Big Drill bit ?
I've never seen drill bits about an inch in diameter.
It wasn't easy, but I got them! A fresh new blade made a HUGE difference compared to the blade that had been used once or twice. I did cut a little too deep and scratched the arm itself. On one of the arms I accidentally pounded the screwdriver between the liner and the arm. Will these mistakes cause any problems, or can I just sand them smooth and press the new ones in?
Pictures of the carnage:
http://tapatalk.imageshack.com/v2/14...9439c3bfed.jpghttp://tapatalk.imageshack.com/v2/14...d1f581ac9a.jpg
These things were rusty as hell.
http://tapatalk.imageshack.com/v2/14...f4057b5d4b.jpg
flash968 08-21-2014 08:03 PM
so, the good news is that you got them apart. the bad news is that you may not like the result. in the blue car i have those bushings that you are about to install. i am on my second set in 35k miles, and i think i am about to have to do a third. they don't last long.
additionally, i don't like how they feel on the street. every little groove and anomaly in the road is sent straight to the steering wheel, and causes tramlining to boot.
great for a race or track car, and when i was setting my car up primarily for track, that made sense. the improved turn in was useful. now that i have taken it off the track, and it is only on the street, not so cool.
i wish i had stayed rubber, and will probably buy new control arms so that i can go back to rubber.
good luck
9FF 08-21-2014 08:17 PM
Originally Posted by flash968 (Post 8225104)
...i wish i had stayed rubber, and will probably buy new control arms so that i can go back to rubber...
Why buy new control arms, just refit the factory bushings back in or better still get the Elephant Racing version which is still rubber but a touch harder than stock but still have the steel liners.
Chunkerz 08-22-2014 04:28 AM
good luck
I'm installing new rubber bushings from Elephant Racing. It was mentioned earlier in the thread.
Those are what I'm using after I clean up the holes.
Edit- several members on Rennlist recommend having the scratches welded. Unfortunately, I cannot find anyone in my area that can or are willing to weld these things :mad:
flash968 08-22-2014 06:48 AM
i like chuck's stuff, and have recommended it quite a bit. i planned to be looking into it, but as i have had a few failures of elephant racing parts over the years, as have a bunch of us, i'm just not sure i wanted to go there again. granted we all have been using the monoball stuff, and it works great on the track. in street application it has shown to be less than optimal, and not up to the beating of potholes and such.
i have not talked to chuck about this new stuff yet though. i just hadn't gotten around to it. it's on my list. i have to take a look at the rear control arm bushings too, to see how they are holding up. i have his monoball stuff there too.
on the 968, the OEM front control arm bushings are not sold separately, so you have to get the whole control arm.
the reason for the delay is that if i remove the control arms, i have to get yet another alignment. it's a pain to have to drive the hour to get there, be there for 3 hours, and then another hour back.
Chunkerz 08-22-2014 07:01 AM
Anyone on here do aluminum welding? I will pay you handsomely.
Are these small cuts really that big of a deal? My new bushings have the metal sleeves. It's not like I cut all the way through. This isn't a track car so they won't see a ton of stress.
flash968 08-22-2014 07:04 AM
i haven't seen the new bushings, but if rubber goes up against that surface, then all you really need to do is smooth it out a bit so there is no edge to catch the rubber.
if a metal sleeve goes up against it, and is pressed in (in other words, not rotating) it is even less of an issue.
speedysprocket 08-22-2014 07:04 AM
Looks like you did get carried away a little with the saw...
Shouldn't be an issue, but maybe to give you some piece of mind, clean it real well and try to fill the cut in with JB weld.
The screw driver notch shouldn't be any issue, but if you have the JB weld out, might as well put some in there too.
Chunkerz 08-22-2014 07:45 AM
I'll get some pictures of the bushings tonight. They do get pressed in. I was planning on sanding the hole to remove the rust and the sharp edges left by the hacksaw/screwdriver.
It was hard to tell how deep I was cutting because the lip of the liner extends over the top of the hole. I'll try the JB Weld if I can't get them welded.
9FF 08-22-2014 08:14 AM
Originally Posted by Chunkerz (Post 8225584)
...Are these small cuts really that big of a deal? My new bushings have the metal sleeves. It's not like I cut all the way through. This isn't a track car so they won't see a ton of stress.
Dude, get it welded up WYIT and feel safe driving, don't use JB Weld. Cuts like that cause great stresses whether you fit steel liners or not, only drive it on the street or not. Its part of what holds the wheel on the car so $60 of welding now or they will copy this post in your obituary if that fails on the highway.
Try this, bend a sheet of card and you will see it bends uniformally, now scribe a thin line on the card and try again. That scribed line will take all the force and eventually fracture at the scribed line. It's a weak point - fix it and be safe!
flash968 08-22-2014 08:29 AM
i'm all for safety, and i never do anything that would be obviously unsafe. that being said, there is a flip side to the idea of welding it.
that thing is aluminum. in order to weld it, you have to heat it up. being aluminum, the heat will not be as restricted to the area intended as if it were steel. that could easily lead to weakening the entire part, rather than a potential fracture point, and making the problem worse than leaving it alone.
from the looks of it, the groove is only about .020" deep. that's really not a lot, and given that the sleeve is going to be in there, and then a rubber bushing, which will mitigate a lot of the force that would be applied to that spot, it may well not be an issue.
this one is sort of a judgement call. i'm not sure which is worse. i'd have to do a lot more homework on the casting process, material composition, and then a stress analysis in order to tell, and you would spend more on that than a new control arm (but likely less than a week in the hospital from guessing wrong)
i agree though about not using jb weld. that would fill the gap, and if the part were rotating, it would help, but it will do nothing for strength.
tough call. a new control arm is obviously the best answer, but also the most expensive.
9FF 08-22-2014 08:37 AM
...that thing is aluminum. in order to weld it, you have to heat it up. being aluminum, the heat will not be as restricted to the area intended as if it were steel. that could easily lead to weakening the entire part, rather than a potential fracture point, and making the problem worse than leaving it alone...
Not really, any decent welder will protect the unaffected area from heat propagation, they do this all the time, it's not rocket science.
Chunkerz 08-22-2014 08:39 AM
Well to get it welded I'll have to find someone to do it. I've called 5 shops and none of them will do it.
Does anyone on this site weld? I will pay you lots of money.
flash968 08-22-2014 08:48 AM
that's going to be very hard to do that on this piece. there is just no way to get in there to isolate the heat. if there were, i'd say "go for it". i've got a really good guy, and i'm not sure even he could do it, without weakening the spot. remember that it undergoes both compression and stretching during operation. cast aluminum that has been superheated like that loses a lot of its strength when you do that. instead of a .020" weak spot, you could have one at least 10 times that deep. i just don't know if it can handle that over the long run. these arms are known to break under stress as it is, which is why race cars have to run charlie arms or something similar. i'm not sure i'd want to mess with it without a lot more information, and certainly some sort of guarantee from the guy doing the work that it wasn't going to be worse than leaving it alone.
as for finding somebody to do it, you'll have to poke around for a fabricator. try calling some machine shops and see who they use to weld engine blocks.
Chunkerz 08-22-2014 03:49 PM
I've contacted every shop in town and no one will do it. I'm gonna go ahead and say **** it and install my new bushings. The cuts really aren't that bad and flash has scared me with his comments about how the heat from welding may weaken the aluminum even more.
If my control arms fail and I end up getting hurt or dying, feel free to say "I told you so."
flash968 08-22-2014 03:56 PM
if i were doing the job, based on what i think i see in the pics, on a street car, i wouldn't hesitate. this is in no way a warranty, but i just don't think it's that bad.
i don't mean to scare anybody about the welding. i am not a welder. i would consult one. i'm not qualified to make that call without a materials analysis, which is cost prohibitive.
i can't believe that none of the machine shops know a welder that does aluminum. that just seems crazy. i know at least 3 within a 5 mile radius here.
Aluminum Welding Services in Maryland (MD) on ThomasNet.com
