what the transaxle
Ok so on top of Bell housing the numbers are 5s 29065 side of Bell houseing ww01
on the transmission it is 016301211f fig 1 LE 85 Germany 4615 F. ggg Anyone know what this all means? |
plays with toy cars
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
I looked there couldn't figure out my numbers from there numbers
It's pretty simple... find the 5S in the first column, which tells you what kind of car it's from, and whether or not it has LSD (it doesn't).
The 5 numbers after the 5S tell you when it was made.... to decipher that, look at the top of the page. It may be rocket science to some, but, if you have the information in front of you, it isn't.
Good luck, George Beuselinck |
