what is this part for?
on my 87 944, Under what I believe is the the powersteering pump there is two electrical prongs that are sticking out. Obviously something is supposed to be attached to it. I have nothing but these exposed brass colored prongs.. what is supposed to go there? what is it for?
Not the best description of what I am talking about, but perhaps someone will know what I mean and what this is.
I can get a picture of it tommorow if need be.
Old 10-01-2002, 09:49 PM
I can hazard a guess, but that is all it is...Does your oil pressure gauge work?
Bob S. former owner of a 1984 silver 944
Old 10-01-2002, 10:34 PM
Thanks Bob, But the guage works fine.
Old 10-01-2002, 10:38 PM
AFJuvat's Avatar
need some more details please.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-02-2002, 02:46 AM
The switch sends a signl to the DME to control the idle when the power steering is operated to prevent the engine cutting out at low engine speeds when parking or similar. Only 944S (16 valve)models have this so if you have a 944 8 valve then someone installed a 944S pump. Apart from the switch, the pumps are identical.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-02-2002, 08:04 AM
Britwrench is correct also if i'm not mistaken there was a letter from porsche saying to remove the plug do to electrical fires caused by that curcuit (had no fuse installed from factory).
Old 10-03-2002, 01:06 PM
