Turbo Swap: Motor mounts
In the process of swapping a turbo motor into my 86 N/A, but was wondering what people have done about motor mounts.
To start with, my current motor mounts are not blown. However, when I did some searching I was confused as to whether there was a difference between turbo and NA mounts. If there is, than I would obviously have to get either OEM or OE equivalent mounts (none of that cheap stuff), or maybe something like a semi-solid from Lindsey or CEP. So first question: Is there a difference between NA and turbo? And Second: With OEM running around $200 a piece, what is the consensus on Meyle, Corteco/Rein, and CEP or Lindsey Ultra mounts? Lastly: Should I bother if my mounts aren't blown? Plans for the car in the coming years: Daily Driver for at least the next 2 years, some AutoX and RallyX, DE, more power.
86 944 N/A (red) |
That Guy
Turbo and N/A mounts are the same.
The OEM are $$$ but will also last the longest out of most aftermarket choices. Have not ridden in a car with semi-solid but for a daily driver i wouldnt go this route. I purchased a set of Rein mounts a few years ago and they were the same as OEM, just with the Porsche part # and stamps ground off the rubber. If you can still find them that would be my recommendation. If your current mounts are not blown and your trying to stay within a budget, i would just leave them. Though you could argue there is no better time than to do it now!
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Toofah King Bad
Ugh, especially on a 951
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
86 944 N/A (red) |
Toofah King Bad
Extra load, extra heat, extra PITA to install after the fact?
