-   -   P/S Power window problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/827544-p-s-power-window-problem.html)
POPS 83 944 08-29-2014 02:35 PM
I have a 1983 944, P/S window will only work off the passenger switch, drivers side switch worked up to when I pulled the door panels. I have tried good switches cleaned the wire connectors in the kick panels. Where should I start next? Does the mirror switch have anything to do with window operation? I know my mirror switch is bad.:confused:
honerboys 08-29-2014 03:42 PM
I feel your pain - I know you have checked the switches but....... it's always the switches - try jumping them at door connectors being mindful of the internal pathways inside the switches - this should point out which switch it is - good luck
POPS 83 944 08-29-2014 03:46 PM
I have cleaned, and moved all the switches and used my extra switches. No go. I used my power probe also it like there is something stupid I'm over looking on the driver side. I just Don't get it worked til I removed the door panels
JonA 08-29-2014 05:08 PM
Just to be clear, when you say cleaned the switches did you take the switches apart and clean the contacts? My problems have always been inside the switches. They come apart easily.
Jon
edredas 08-29-2014 05:31 PM
The switches must be assembled in the correct orientation for them to work on passenger side.
924Board.org :: View topic - Window problem electrics?
honerboys 08-29-2014 06:51 PM
true what edredas says - if you took switches apart they have to be put back together in the correct way - check your fuses - did the switch smoke at all - these switches are a joke - but not in the funny way - the power does go through the drivers side over to the pass. side so if pass. switch on drivers side is messed up pass side switch won't work
POPS 83 944 08-29-2014 09:26 PM
Jon
Yes, complete taken apart, cleaned and put back together
POPS 83 944 08-29-2014 09:32 PM
Yes, put together correct ( i'm going to recheck to make 100% positive. Would be nice if i just did a knob and assembled them wrong) all other switches are working even if I rotate the switches to other window. No smoke, maybe I'll look at the relay and make sure the connectors are clean. They way it is acting almost like the D/S switch isn't grounding but my power probe is showing ground:confused:
Thank you for your ideas on this !!!
POPS 83 944 08-29-2014 10:26 PM
I just went and tore both switches apart and BINGO one WAS put back together with the contacts backwards. YEA BOTH switches now work. You guys rockhttp://forums.pelicanparts.com/suppo...s/beerchug.gif. I was going crazy trying to find the problem. Thank you for making me recheck my workSmileWavy
edredas 08-29-2014 11:00 PM
