Heads Up - Potential Fires for Early Cars
The Wittrin brand Air Conditioning System Relay sold on this site
924S/944 (1983-01/85) Part Number 944-615-113-022-M504 ...melts at terminal 30 and might catch fire. ![]()
Peace to the Brave +++ 1983, 1984, 1987 944 N/As |
one of gods prototypes
May not be a relay problem, check the current draw, if the compressor clutch or fans are on their way out they will draw too muchcurrent which will over heat the relay
Checked all of that. Fans are brand new.
Replaced it with my spare Stribel and the problem went away.
Have 944, will restore
Good to know either way. The headlight switch is also prone to melting and causing a fire through faulty grounding and contacts in the headlight circuit. I'll give my a/c relay a check for good measure!
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
