Have 944, will restore
mazdaverx7's Avatar
Camshaft Question
After installing the cam box on the cylinder head, should the cam gear be able to be moved by hand? The reason I ask is because I followed the Clark's Garage install instructions when installing the cam box on my 86 and I aligned the marks on the cam and the backing plate as instructed and bolted the cam box in place. The timing marks are lined up but the cam gear will not move by hand. Should it be able to move by hand a few degrees? Engine is at top dead center with a flywheel lock in place. No belts are on the engine.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 09-06-2014, 04:42 AM
The newest of the noobs!
grendiers's Avatar
Not sure it can move a degree here or there, I just leave it alone. Some of the cam lobes are pushing down on the valve springs. And, if it does move, it will move somewhat violently! So, don't turn it!
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 09-06-2014, 05:45 AM
I don't think "by hand" is a literal term. Turning the engine over 'by hand' means to use a tool and do it manually without the help of the starter. It would depend on how strong you are that you can move the cam without a wrench. However, if you are using a wrench then I've misunderstood and the cam is binding, which is a problem.
1986 944 -Garnett w/Koni suspension
1987 924S -Red, 951 Swapped, ~300hp
1987 924S -Red, project car
1987 924S -White, Project car
1988 924S- Red, Bone stock, Daily driver
Old 09-06-2014, 11:08 AM
mhariush's Avatar
You won't be able to move it by hand, unless your fingers are freakishly strong. Use a wrench, there's a spot on the cam (at least on the 16V ones) that has a castings for a wrench.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 09-06-2014, 12:07 PM
honerboys's Avatar
I would not attempt to move it unless all belts are installed making sure all marks are good
84 928 S - SOLD
2012 Cayenne S
Old 09-06-2014, 12:24 PM
