Idle drops when gas pedal released
Hmm, I did search this but I didn't have any luck...(my ignorance I'm sure).
My '87 924s starts fine and has no trouble maintaining a steady idle of about 950 rpm; however, after revving the engine and releasing the gas pedal the tach falls to about 900 and then goes back to 950. Is this symptomatic of a vacuum leak or is it something else? All suggestions greatly appreciated. |
Sounds normal to me.
Clifton |
Perfectly normal for Bosch injected cars with the "barn door" airflow meter. You let your foot off the gas, the flap in the airflow meter snaps shut, and it takes a second for the idle air bypass to take over.
Whew! Thanks everyone!!!
Ill take "What is, slow to respond engine control systems from the 80's" for $500
Regards Dave |
| All times are GMT -8. The time now is 09:38 AM. |
