-   -   My turn signal relay is buzzing (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/829999-my-turn-signal-relay-buzzing.html)
GloriaRedStang 09-15-2014 10:40 PM
And I mean buzzing loudly, like an alarm!
I have a 1984 n/a. Anybody have an explanation and/or fix for a buzzing turn signal relay under the dash? It sounds when ignition is off and turn signal lever is centered (not signaling left or right turn). If I turn key one click in (power on but no ignition), the buzzing stops. If the engine is on, the buzzing is off.
If I pull out the relay, obviously, it stops. Other conditions: my dash blinker is out, but it's been out longer than the buzzing, which just started yesterday.
Is this something that replacing the relay will solve? Or cleaning a ground or replacing a fuse?
I don't know how to chase a short, but if that's it, can somebody point me to the likely culprits/locations?
This might cause me to fail my overdue safety check. Thanks in advance.
GloriaRedStang 09-17-2014 03:31 PM
bump
tinppa 02-23-2015 08:34 AM
I have the same problem, does anyone have a solution for this??
Bradical 02-23-2015 11:45 AM
Relay buzzing is caused by age and wear on the relay- as the contacts become worn the coils begin vibrate as the sets of contacts are sitting uneven. Occasionally this symptom can be caused by under-powering the coil, perhaps due to dirty points, but the former is much more common. Replacing the relay should do the trick.
tinppa 02-23-2015 11:56 AM
Thanks but, have tried several relays, wont fix the problem.
Bradical 02-23-2015 02:24 PM
Do you have access to a meter? What is the voltage supplying the coil while it is buzzing?
Jfrahm 02-23-2015 04:18 PM
I would suppose some stray current is grounding through the relay. Try pulling fuses one at a time and see which ones affect the buzzing, then look for a reason why those circuits are connected. Maybe something like the turn signal switch is involved (headlights?)
Has the headlight bulb wattage been increased?
