Bat wing/splitter questions
A couple of quick questions:
Are bat wing/lower valances interchangeable? Specifically, would a 944 turbo bat wing fit on a 968?
Also, if you're running a front splitter on a 968, do you even use the bat wing? Thanks!
Jeremy
Old 09-25-2014, 10:19 AM
flash968's Avatar
no to interchangeability. the width is quite different.
unless you are running the D1R splitter (and possibly the strosek), you still have to use the OEM lower apron
Old 09-25-2014, 10:34 AM
Thank you!
Old 09-25-2014, 11:50 AM
flash968's Avatar
no worries.
Old 09-25-2014, 11:58 AM
