Making the hand brake cables tighter than you could pull them by hand?
You don't even need to do that. You can do it with out putting the car in gear, etc...
Remove ignition coil wire, take your 24mm socket and a breaker bar, position the socket and breaker bar on the crank bolt on the driver side so it is not touching the ground, but is close, then crank the motor. Use the piece of wood if you are not on solid ground, or you don't want your breaker bar to get marred. |
To help illustrate Matt's approach, here is a picture of him working on his truck:
http://tatfoundation.org/man_under_truck.jpg |
lol. That guy has it better than me!
| All times are GMT -8. The time now is 05:21 AM. |
