More Boost!
Cheaper Alternatives for the Transmission Plugs?
Doing the rear diff fluid replacement and looking to replace the drain/fill plugs since they are rusted and stripping. Does anyone know the VW cross reference part for these 17MM allen bolts.
try BMW Drain plug 23 11 7 546 876 (w/magnet) and Fill Plug 23 11 7 527 440
looks like: ![]() |
Going faster all the time
they aren't that much on pelican are they?
Seems like your time is worth more than this.
Now: 1997 German-built Boxster - Black Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray |
I doubt that you will find cheaper than $3.50...
Pelican Parts - Product Information: WHT-001-937-OEM
Good luck, George Beuselinck |
More Boost!
Pelican it is
$3.50 it is then, should I use both anti-sieze and telfon tape to prevent these buggers from becoming a pita to remove in the future? From what clark's-garage says, 18ft-lbs are the torque down specs too, any objections?
No need for teflon tape or antiseize. The reason that most of those plugs are damaged is due to gorilla hands tightening way beyond what is necessary. You just want enough to keep the plug from vibrating loose (i.e. not very much). Eighteen lb ft sounds about right.
More Boost!
The Haynes manual says 30ft-lbs iirc, I wonder were these numbers are coming from...
Patrick
Here's the page from the service manual, Sec. 30 (Transmission).
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
I'm shocked, shocked that the Haynes manual is wrong.... (sarcasm).
plays with toy cars
I have VW drain plugs, literally the exact same thing as the ones on Pelican. I think they were $1.50 each or something.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
More Boost!
AFM #725
I kept my original plugs muahahahaha living dangerously
