brake fluid reservoir and dash indicators
here are a few scenarios I am interested in:
what happens - e.g. on the dashboard after turning on the electronics - when:
* the brake fluid reservoir gets too low
* the brake fluid reservoir has been disassembled
* the brake fluid reservoir terminals are corroded
87 944 NA
Old 10-02-2014, 07:20 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
You should see a "brake" warning light when the reservoir drops below a certain level due to the position of the floating sensor in the reservoir. Also, if the terminals are corroded, you may get no warning at all because of loss of voltage to the warning light.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 10-02-2014, 08:05 AM
thanks mytrplseven
Originally Posted by mytrplseven View Post
You should see a "brake" warning light...
would that specifically be the "BRAKE PAD" light? that's all there is I think, at least for my late MY...
87 944 NA
Old 10-03-2014, 05:12 AM
Bradical's Avatar
Originally Posted by Bukowski View Post
thanks mytrplseven
There is a BRAKE and a BRAKE PAD light that are seperate iirc
Old 10-03-2014, 05:35 AM
What about intermittent brake fluid light? It seems to come on randomly when going over bumps and stuff. Is the connecter corroded?
Sent from my SPH-L720 using Tapatalk
Old 10-06-2014, 05:55 PM
Have 944, will restore
mazdaverx7's Avatar
Check your fluid level. If the brake fluid level is correct then you may have a faulty sensor or bad or corroded wiring.
When the fluid level is low the center warning light "!" will illuminate and there will be another red light that illuminates indicating the fluid is low. I believe it says "BRAKE FLUID". Just had to add some brake fluid on the 86 that I'm restoring. Those lights came on over crests and bumps.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 10-07-2014, 02:42 AM
all - thanks for the info, I have enough to work with. I also appreciate the questions - however, I really intend for this to be limited to the three scenarios I listed - and didn't want to make it an endless debugging session - that can, and may, come later!
87 944 NA
Old 10-07-2014, 06:51 AM
Thanks!
Old 10-07-2014, 08:15 AM
