NEED HELP FAST! Can't find sensor bracket.
Hey guys/gals. I know I'm a noob here as well as a noob to owning a Porsche. This is my first and it's an 83 944 N/A. I got it and the reference sensor was bad. i tried to pull the sensor out and broke the bracket that retains the reference/speed sensors. I cannot seem to find a bracket that matches this one. Can anyone help me find where I can get the correct bracket? The part number on the bracket is 944, 101 3212R. Please help as this is going to be my DD as soon as I get it fixed and I have 2 brand new OEM sensors with no home. Also I was thinking of just welding this one back together (The bottom screw hole is what broke) however I tried everything I could think of to remove these two sensors and they will not budge. I'm guessing they will have to be drilled out. Any and all help would be greatly appreciated.
Very Respectfully, Justin |
There's one on ebay item#111481303786
Thank you but that is not the correct bracket. I searched ebay and cannot find one that is the same part number/design. The one I need is 944, 1013212R I just can't seem to find the part number anywhere. There has to be one somewhere.
Pic?
I have them see my tag or pm me
plyhammer i've sent you a PM
You likely have an early bracket with a diagnostic sensor on it (3rd sensor). This is a vestigial piece, and may be replaced with any 2.5 sensor bracket from the scrap yard.
The bracket I have has only 2 sensor holes. It does not have the 3rd sensor spot i've seen on some of these other brackets.
The 3rd hole is for a dealer timing light atatchment and isn't needed. ..... The sensor in the 3rd hole closest to the drivers side is that sensor you don't need.....
Were you able to locate one?
Plyhammer is who I'd buy it from! Always the right part with the best prices. I should get frequent buyer points buy now Mark! ...Just sayin'
