Brake fluid reservoir cap leads
before I break something - how should the leads for the brake fluid reservoir cap terminals be removed - just pull pull pull until POP they're off, or is there some way to squeeze them? Mine are stuck on pretty good.
87 944 NA |
Andrew Gawers' Dad
They just pull off. Pull the plastic, not the wire.
thanks, it worked - I used a stiff putty knife and gently rotated, worked.
follow up question: can the terminals be pulled out w/o damage? Mine have obvious green copper corrosion inside the plastic area. Follow up to that : can the tiny mechanism inside be cleaned out?... should moving the float up/down make a lamp turn on/off on the instrument panel? yes, I know Pelican has a $40 cap for sale - but I didn't know until looking there's a $10 cap that lacks the float mechanism - pretty cool. third follow up : any suggestions how to clean the pinch type terminals on the lead? a thin wire pipe cleaner? where do I get that?
87 944 NA |
Update
The terminals come out but it takes some firm tugging. The rubber septum is held down by a plastic ring - the ring has to come out first. I can't tell if the float can come out. I took pics if anyone wants to see.
87 944 NA |
