KerryChadderton's Avatar
AFM problem ?
1984 N/A, stock engine, catless with Flowmaster muffler: DE car
I'm running into a weird and hard to duplicate problem. Earlier this year I upgraded to the '86 DME & AFM and added a 4^ advance cam key. Engine feels great and I like the smoother idle and improved lower end torque.
I tested the AFM prior to installing using the Clarks garage and The944.com procedures. Bench performance was spotless.
In August on the way to a DE I noticed that during long highway driving at steady throttle the engine would occasionally bog and the AFR would go into the 17 to 18:1 range. WOT throttle would clear this up instantly and it would last for anywhere from 20 minutes to several hours. I cleaned the AFM connector and had no more trouble during the DE, nor the ride home.
This Friday I had another DE. I had the bog & AFR problem one time during the 3 hour trip there. I cleaned the AFM connector again but it was spotless anyway. During my first two sessions the car seemed okay but lap times were 2-3 seconds off. Then I started to pay attention the AFR. At idle the AFR would slowly work its way from 14.6 to 17.1. Snap the throttle and the process would repeat. On track WOT AFR readings varied from 13.1 to 10.8. This was worst on the last session if the day. The power was flat and the car slow.
During the 3 hour trip home the bog came a couple of times but the car is very drivable and reliable otherwise.
Before I spend hours chasing gremlins, have any of you experienced these symptoms?
'84 944 N/A - 944 Spec Suspension & Brakes, Stock Engine, Catless w/Flowmaster, '86 DME/AFM, 4^ cam advance
Old 11-10-2014, 03:50 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I'd look at a loose AFM connector (or bad connections), vacuum lines connected to the FPR or FPD, also consider another easy component, the Fuel Filter or loose electrical connection to the fuel pump. While on that tact, possibly the DME relay could be going. They're only about $20 to replace so I'd consider that as well (I recommend always carrying a spare in the glove box).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 11-11-2014, 08:50 AM
Toofah King Bad
Rasta Monsta's Avatar
+1. If AFM bench tested OK (and you are confident with your test procedures), you have a fuel delivery problem. I'm leaning toward the pump or pump inlet screen.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-11-2014, 09:11 AM
Thank you for replying guys. I'll take your advice.
I did replace all vacuum hoses and the fuel filter within the last 1,000miles. The part that confuses me is that I've got a lean condition at idle/steady mid-throttle, and a rich condition at full throttle. To add insult to injury it is not an every time, every condition. However it does seem to be getting worse.
In my mind the AFM, or AFM wiring would definitely cause this. On the other hand do either of you think the FPR/FPD would cause this? Maybe the throttle position sensor?
The reason I ask is the problem's sensitivity to throttle and the wide range of indicated, real time AFR data. I don't know...just thinking out loud...
Old 11-11-2014, 03:24 PM
