LinkBack Thread Tools Rating: Thread Rating: 3 votes, 4.00 average.
less I know,more I learn
Backyardbodyman's Avatar
86 944 street racer & part time track day project
I love seeing peoples projects & their progress. So I wanted to show you mine. Car is in white primer & will get one final block sand,wet sand & white paint.
Old 10-15-2014, 06:01 PM
Looking fantastic so far!!
Where in Ontario are you?
Old 10-15-2014, 06:32 PM
TrailRider's Avatar
very nice work!
'87 944 Turbo / '01 996tt
Old 10-15-2014, 07:07 PM
Thanks. I'm in Caledon
Old 10-15-2014, 07:11 PM
Originally Posted by TrailRider View Post
very nice work!
Thanks. Lots of fun. The 944 has so much potential
Old 10-15-2014, 07:15 PM
Northern Motorhead
wildcat077's Avatar
Wow,
That is one clean looking car,nice work on the dash !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-15-2014, 08:17 PM
Originally Posted by wildcat077 View Post
Wow,
Cheers
Phil
Thanks. I'm very happy with the way the dash turned out. It originally looked hideous. It was full of cracks. To hard to find a good one,so I fixed it bodyman style. I chamfered all the cracks with a razor & filled them in with cheese(body filler),filled in the vents.block sand & several thick coats of polyester primer. I'll see if I can find some pics of the dash project,help people transform their cracked dashboards
Old 10-15-2014, 08:41 PM
👍 lots of work there. Nice clean work
Old 10-16-2014, 09:13 AM
Toofah King Bad
Rasta Monsta's Avatar
+1 on the dash, very well done.
Have you considered completing the cage while you have it apart? Easier now than later.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-16-2014, 09:45 AM
Going faster all the time
Litesonic's Avatar
Very cool. I too am a fan of the dash.
Now: 2006 Cayenne Turbo S Titanium Gray | 1986 944T Black
Then: 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory
Old 10-16-2014, 12:06 PM
yundar's Avatar
Very Nice!!
What is the T handle for? Are you doing the high performance Toyota Pickup handbrake swap? :]
Old 10-16-2014, 12:49 PM
Thanks everyone, I appreciate all the compliments. I have thought about welding front bars to make a full cage. I'm going to leave it for now. Focus on getting it back on the road. The aluminum T handle is for a battery cut out switch.
I'll post some pics of consol when I'm done. Lots of fun
Old 10-16-2014, 02:17 PM
So many little things to do. I just keep inventing more.
Raymond
Old 10-22-2014, 01:58 AM
Litesonic's Avatar
so cool. love the simplicity.
Old 10-22-2014, 08:54 PM
Right on,trying to keep it as light as possible. I'm going to pack as much punch as I can into a naturally aspirated motor. I'm gonna start building motor when the snow starts falling.very soon up here. Door panels not finished yet
Raymond
Old 10-23-2014, 04:16 AM
dp951's Avatar
very nice luv the battery disconnect
Old 10-24-2014, 10:49 AM
Straight shooter
Lapkritis's Avatar
Hafta ask - what are you planning for a powerplant?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 10-24-2014, 01:06 PM
Please, please, pleasssse provide details on that dash repair.
Freakin' awesome. Can it be painted any color, or is that aluminium (or aluminum) look part of the process?
Also, noticed you filled in all the vents. Is that required for this approach, or you just chose to do it that way?
Old 10-24-2014, 02:47 PM
Thanks,it burns my *ss when people say you can't get any power with a naturally aspirated motor. In spite of that,I know there's plenty of power to make with na motor. For the short block-bored & steel sleeved,knife edge crank,forged rods,JE forged pistons(higher comp),stage 2 port & polish by Lindsey r,wide fire gasket,#274 web cam shaft,1 piece header,2.5" exhaust with electric dump,lightend flywheel & balance shafts,alum crank & alt underdrive pulleys,fuel rail & so on. If it doesn't feel fast,I'll give it some laugh gas(nos),he he. Start out with 50hp jet. Car's gonna be fully lightend. I'll look for some pics of dash project. I filled in the vents cause its easier. Plus I don't need them. I post more pics as move along. Cheers
Forgot to mention,you can paint the dash any color. Bright color wont get hot & give off heat under glass. It's an aluminum plate in center with gauges.
Raymond
Old 10-24-2014, 08:52 PM
Raymond
Old 11-07-2014, 02:32 PM
