Bradical's Avatar
Brake Hoses
Hey fellas, quick question...
I am replacing my brake hoses with the stainless steel variants from Lindsey Racing. Should I reuse the spring protectors? Search yielded nothing.
Old 10-31-2014, 02:41 PM
Just thinking out loud
mattdavis11's Avatar
What are spring protectors?
91 FJ80
84 Ram Charger (now gone)
Old 10-31-2014, 09:09 PM
Bradical's Avatar
On the stock brake hoses up front their are some "springs" that wrap around the length of the hose to protect it, I would think the stainless steel mesh does that job but I was just wondering what other people had done.
Old 11-01-2014, 05:41 AM
'68 911 / '86 944
I've run the braiding lines for 5 years without anything on the outside of the lines. No wear from rubbing on the springs. Just make sure you are using flare nut wrenches so you can tighten the fitting properly and get the "alignment" of the brake line so that it will not rub on anything.
Old 11-02-2014, 06:24 AM
