How much clack from this fellah?
So my car had a pronounced knocking noise, a couple of bits are missing from the skirt of piston 3, and I think it might be cracked too. So did this cause the noise, or will it prove to be the bearings which are knackered now from metallic bits in the oil.? The investigation continues.. too damn slowly as other life stuff keeps happening.
![]() Cast your votes now.. My guess is that if it were cracked across at the little end, that would possibly make a hell of a clack. :-) cheers Rissole
944 Alpine White '89 2.7L |
That does not look good at all.
1981 924 Turbo 1987 N/A Auto Black w/Can-Can Red Interior |
Patrick
Ouch.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
progress this evening
So managed to take a few more things apart this evening.
I turned the engine over, and took the head off. Didn't look too bad from this side. ![]() The Head looks OK, though running a bit rich... ![]() ![]() And this is the state I abandoned it in after a couple of hours this evening. Oh for a decent sized garage. ![]() Tomorrow, I start taking the pistons out, and can have a look at the damage... cheers Rissole
winter-hater club member
wow. that looks $$$$.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
plays with toy cars
Sell good 2.7 head for $1000+ and you can swap right to a good turbo or 944S motor!
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
How the hell did that happen? Bent connecting rod?
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
Not for the faint hearted
Ok, here we go.
Piston out. Yep, pistonbroke. ![]() Bad bore. Oh this is nasty... ![]() T'other side. Think this bore maybe beyond recovery... ![]() ![]() And a nice one... the other 3 are like this. ![]() Hmmm. So what happened.? Did the piston fatigue crack first, and then flap wildly scoring the bore so horribly, or did something clout it to knock those skirt chunks out, with it cracking later. Hey Ho. The fun continues... Cheers Rissole
that'll buff right out.
One apex at a time
You will never know for sure it could have been detonation or just fatege after years of use.
The real question is rebuild or new / used motor. |
okay, i am going give one possibility: i am thinking that the piston skirt lost part of its coating and then the galling started. that led to some eventual binding/wear which cracked the piston.
You can get the bore(s) replated at US Chrome. I've had them do a GSXR aluminum block motor for me, about to maybe send another their way, and another buddy (eorhnberger) had them do his 944S2 motor. They'll need the pistons too, to match it all up. They're the ones everyone else sends the business to, it seems. Cut out the middleman!
![]() U.S. Chrome Corporation of Wisconsin Cylinder Repair Company Sadly, in my most recent case, the piston looked far worse than yours, thanks to dropping two intake valves at 12,500 rpm! Sorry, no idea re: your piston failure...
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
