Magical Mystery Brackets
I took these off to throw them in the ultrasonic cleaner, and now I've completely forgotten where they go. To make it worse, my (now ex-) phone accidentally met concrete at high velocity, so I don't have pictures of where they went. I'm guessing they belong together, presumably somewhere under the intake manifold. Any guesses?
1987 Guards Red 924S
1986 White Toyota MR2
Old 11-12-2014, 05:28 PM
winter-hater club member
nynor's Avatar
this might jog your memory:
944online.com Exploded View Porsche 944 Diagrams.
the smaller one is also a support bracket for the intake manifold, IIRC.
"COOL PRIUS!" - Nobody Ever
Old 11-12-2014, 05:51 PM
nynor's Avatar
actually, i think the smaller one is a support bracket towards the back of the airbox.... it's been way too long....
edit: actually, i think this is the speed and reference sensor electrical connector mounting bracket which is located at the back of the intake manifold.
Old 11-12-2014, 05:53 PM
Yep, that would be it. Thanks. I guarantee I looked right at it when I scrolled through the PET, but I still missed it...
The little one appears a few times in the engine compartment, so I'm guessing there's no telling which one it is without looking at my engine bay. If I can't find a good place for it this time, I'll screw it in somewhere it won't fall off and try again next time. It may just be a wire mount.
Old 11-12-2014, 05:59 PM
nynor's Avatar
you jogged my memory. i think that is exactly what it is. it bolts on, somewhere below the intake manifold and wires are wire-tied to it.
Old 11-12-2014, 06:04 PM
Yep, I"m going with that. No idea why I took it off...
Thanks again!
Old 11-12-2014, 06:27 PM
mall one looks like the bracket that mounts to the rear cam cover, then to the exhaust sniffer tube.
Old 11-15-2014, 04:09 AM
Argiopeweb, they are wiring mounts as you said. I've circled them in this picture.
I hope this helps!
1986 944 -Garnett w/Koni suspension
1987 924S -Red, 951 Swapped, ~300hp
1987 924S -Red, project car
1987 924S -White, Project car
1988 924S- Red, Bone stock, Daily driver
Old 11-15-2014, 11:39 AM
edredas:
Like a boss. That is indeed what they are. I will note that the 90° angle appears many places on the engine, including the rear cam cover.
Old 11-15-2014, 03:17 PM
