Sway bar bushing brackets
I'm looking for a new pair of the loop brackets that hold the inner bushings on the front sway bar, that will fit part # 477-411-053-G-M260 (20mm bushings)
My old ones are both corroded and too big for the new bushings, even though they are the right bushings for my car. If anyone can verify that the brackets sold on Pelican (part # 944-343-731-02-M100) will fit these bushings and aren't bigger like the original brackets, that would be great. Or if you have a pair of good used ones and can send me the interior diameter of the loop--should be right about 35mm when tightened. |
I found a great deal on an upgrade to a larger sway bar so I'm going for that.
| All times are GMT -8. The time now is 05:16 PM. |
