Clutch slave-to-hose hard line
confused about what line in the PET clutch diagram I need - on the car, it's a single 6 mm hard line between the clutch slave and the combination hose/line that goes to the slave. The PET has two lines that might be it.
Which number is this part? I looked all over the brakes section of the Pelican site, couldn't find it. |
The combo hose you need is for left hand drive pedals P/N 477-721-189 and the short hard line which is called the clutch pipe - line is P/N 944-423-091-00
Cheers Phil |
944-423-091-00 makes sense, but is NLA
What diagram/PET is the 944 423 091 00 found in?
It's in the Group 6 Brakes, Section 604 page 133 of 317
You can easily fabricate that line or maybe even purchase a pre made brake line if the fittings are the same. Cheers Phil |
| All times are GMT -8. The time now is 09:19 AM. |
