replacing steering rack
In the process of replacing the steering rack and the tie rods. The passenger side tie rod came in with no problem but the drivers side refuses to budge. Any suggestions on removal would be greatly appreciated.
Old 12-10-2014, 10:28 AM
M. Murphy's Avatar
Replacing steering rack
If you are not concerned about re using the tie rod a pickle fork and hammer usually makes short work of the job. If you do want to save them there is a screw clamp devise that will press the taper out. Both of these tools can be purchased at Harbor Freight.
Old 12-10-2014, 12:31 PM
944tothefloor's Avatar
If you drive near an Oreillys or napa or whatever, they usually rent them for free. Ask them about tool renting service.
Old 12-10-2014, 02:35 PM
Toofah King Bad
Rasta Monsta's Avatar
If you beat the end of the steering knuckle on the spindle with a BFH it should pop out.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-10-2014, 03:40 PM
tried pickle fork-destroyed the tie rod but still will not come out!
Old 12-10-2014, 11:45 PM
Toofah King Bad
Heat and beat.
Old 12-11-2014, 07:29 AM
p-talk's Avatar
Yep, a screw clamp device will get it done without damaging the joint. The Harbor Freight online catalog doesn't list the one I bought last month for cheap, but it looks like this:
http://www.summitracing.com/parts/sps-37990
1984 Porsche 944 - Mathilda the needy
2010 Audi A4 Avant - daily driver
1990 Audi 200 Turbo Quattro Avant - recently wrecked, future uncertain . . .
Old 12-11-2014, 07:36 AM
Toofah King Bad
But if it's super stuck that tool will break.
Old 12-11-2014, 08:23 AM
Proprietoristicly Refined
John_AZ's Avatar
...and I bet your arm and shoulder needs some Bengay.
Go to the FLAPS and rent/deposit free the correct tool.
J_AZ
1988 924S, 80K ..+ 1987 924S, 150K DD (+15K est. bad odo)
Old 12-11-2014, 08:40 AM
That Guy
Techno Duck's Avatar
If you use the type of tool above, leave it on (and tensioned) for a few hours and it will probably pop right out on its own.
If that doesn't work, slowly start applying heat to the steering knuckle.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-11-2014, 04:25 PM
that same tool from Harbor Freight, cheesey as it maybe, worked for me. Cheesey because I dropped the pivot pin and the damn thing broke (the pin). Been using a large punch in it since.
86 951 blk
Old 12-14-2014, 06:42 AM
p-talk's Avatar
That's the one.
Old 12-15-2014, 07:25 AM
Rented one from Autozone popped out in about 20 seconds.
Old 12-15-2014, 08:51 AM
p-talk's Avatar
Hurray for the right tool
Old 12-15-2014, 02:16 PM
